John Wick: Chapter 3 - Parabellum
Re: John Wick: Chapter 3 - Parabellum
RB 00434.mpls is not correct. Library scene all messed up.
Amazon retail bluray, tried 275. It was messed up at the library, and then messed up again when he showed up to the Russian ballet theater, so I gave up.
RB Main Feature 434 has library scene out of sequence with latest Java and Makemkv. 965 shows in procman and sequence is correct.
I just wanted to say that I just checked the library scene (and just the library scene) for RB 429 and it was correct on my disc. So it looks like there might be two different RB discs out there. 965 is correct if it's available, otherwise go with 429.
Just verified RB 0429 as earlier posted and can confirm from beginning to end everything was in order.
Just Confirmed - Correct segment for RB-t-bone- wrote: ↑Wed Sep 11, 2019 3:55 amSeems like 429 for RB worked for me.
Name: John Wick 3: Parabellum
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
File name: John Wick 3- Parabellum_t167.mkv
RB US - With MakeMKV I got 921 as Main Feature. Watched first 10 minutes and it seemed right.
My disc doesn't have any of the proposed titles - 965 429, 921, or 957.
It's the 4k Ultra / BR bundle
Have you guys tried running the BDMV file through BDInfo to get the correct playlist? Use Makemkv in backup mode to get the BMMV file then run it through BDInfo to display the playlist.
I may be missing something, but I downloaded and tried to see how this would help but it was not obvious to me.
My MakeMKV was listing 434 as the FPL_MainFeature. The root of the disk structure labeled it retail.
Source information
Type: Blu-ray disc
Name: John Wick 3: Parabellum (English)
Comment: BD-130923_JohnWick3_Retail
So, perhaps retail and rental disks make it into the Kiosks?
How do you know if the library scene is wrong? Is there a target timeline to view and test?
Because JW was already fighting someone, and in the next segment he was just meeting him.Mysus456 wrote: ↑Wed Sep 11, 2019 10:09 pmI may be missing something, but I downloaded and tried to see how this would help but it was not obvious to me.
Source information
Type: Blu-ray disc
Just done a run through and makmkv shows this as the FPL_MainFeature
504,512,509,511,518,506,514,519,505,516,507,520,510,502,508,503,501,515,517 - 00396.mpls
but after looking it looks like this is the correct one for me.
504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517 - 00444.mpls
I spot checked it against the DVD and the time codes look the same.
All the play lists start with 504 and end with 517.
Amazon preorder Blu-ray - DVD - Digital.
Title information
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t380.mkv
Redbox version using Process monitor.
Duration: 2:10:45
Chapters count: 16
Segment count: 19
