John Wick: Chapter 3 - Parabellum
bretb
Re: John Wick: Chapter 3 - Parabellum
#31 Post by bretb » Tue Sep 10, 2019 9:04 pm
Sterling74 wrote: Tue Sep 10, 2019 8:42 pm
Mystic95z wrote: Tue Sep 10, 2019 8:27 pm
debof14 wrote: Tue Sep 10, 2019 6:51 pm Yep thats the encryption working against you ...make sure you are on latest java install and make mkv version ... I see 965.mpls
Seriously doubt that. From process monitor the segment map from the disc I have is 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506 and matches up to 00429.mpls. Gotta wonder if they are now sending out RB discs with different obfuscation. But btw I do have latest versions of both....
Mystic95z - I agree with you too. I just finished scanning a RB disc to compare against the one I bought from Best Buy. The RB Blu-Ray disc is using 00429.mpls according to Proc Mon and that lines up with the order you have as well (510,511,502,505,512,501,519,516,508...). The RB disc did NOT have a playlist number 00965.
So, as of now, I think 00429 is the correct one for the disc I have.
From 00424.mpls to 00431.mpls on this RB disc. :(
There is no 00429.mpls
Surely there are not two different version of RB disc obfuscation. Surely not!
NeoCortex
#32 Post by NeoCortex » Tue Sep 10, 2019 9:09 pm
That's what my RB disc has as well. So I'm going to just go with that.
I know it's normal for there to be different versions between retail/non-retail. Is it common to have multiple versions just among the RB discs?
shnorgleton
#33 Post by shnorgleton » Tue Sep 10, 2019 9:30 pm
bretb wrote: Tue Sep 10, 2019 9:04 pm
Just got a RB disc and mine's using 00965.mpls with the segment map 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501. Interesting!
Gojira74
#34 Post by Gojira74 » Tue Sep 10, 2019 10:21 pm
Unibrowser wrote: Tue Sep 10, 2019 8:31 pm I bought the 4k/1080p retail version today. I'm not sure if the titles that are (main feature) are correct. I seem to have very different playlists than other people. I'm most cases in the past the Main Feature listed one is correct. Can anyone confirm this?
http://imgur.com/gallery/mgNTLCo
[s]I ripped this #275 (blu ray) as shown from my Best Buy 4K steel box copy, and it looks like it's correct when I scanned through the movie by eye. I may have missed a weird shift, but it looks correct.[/s] - WRONG sorry
MarkRMonaco
#35 Post by MarkRMonaco » Tue Sep 10, 2019 10:40 pm
Here is my RBx copy of the movie... 00434.mpls seems to be the correct one. 00965 is present on my disc but is not labeled.
BobbyD1891
#36 Post by BobbyD1891 » Wed Sep 11, 2019 12:15 am
Gojira74 wrote: Tue Sep 10, 2019 10:21 pm
I do not think this is correct. the library scene was messed up for me
Gojira74
#37 Post by Gojira74 » Wed Sep 11, 2019 12:23 am
BobbyD1891 wrote: Wed Sep 11, 2019 12:15 am
Yeah, you're right. It's jacked in the library.
maiteekwin
#38 Post by maiteekwin » Wed Sep 11, 2019 1:09 am
hvnphoto wrote: Fri Sep 06, 2019 5:13 am Title information
Name: John Wick 3: Parabellum
Source file name: 00444.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t180.mkv
I obtained this as well from the process monitor for the blu-ray from BB blu-ray/dvd/digital
Rav0z
#39 Post by Rav0z » Wed Sep 11, 2019 1:41 am
I used the Process Monitor method that was highlighted earlier in this thread. I do not believe it is accurate for finding the correct mpls for this movie. For the RB disc, process monitor came back as playing mpls 453. But when looking at that mpls in Makemkv there are actually two 453 mpls's, and they are obviously not the movie. They are not 32 gigs in size, and only contain 6 and 8 chapters.
Perhaps I did something wrong? I used Corel WinDVD Pro to play the disc. I followed the tutorial that was linked. Non the less, mpls 453 is obviously incorrect.
mikecox900
#40 Post by mikecox900 » Wed Sep 11, 2019 2:41 am
my redbox was 965 it warks perfectly hope it helps
Revilo17
#41 Post by Revilo17 » Wed Sep 11, 2019 3:37 am
Title information
Comment: FPL_MainFeature
I rented this one from Family Video, you will have to update to version 1.14.5, then Libredrive mode on WH16NS40.
The RB Blu-Ray disc is using 00429.mpls is correct
-t-bone-
#42 Post by -t-bone- » Wed Sep 11, 2019 3:55 am
Seems like 429 for RB worked for me.
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
File name: John Wick 3- Parabellum_t167.mkv
BobbyD1891
#43 Post by BobbyD1891 » Wed Sep 11, 2019 4:35 am
damn...still looking for the best buy/retail version. all of my segments start with 518
srteach
#44 Post by srteach » Wed Sep 11, 2019 5:12 am
jeflatt wrote: Tue Sep 10, 2019 7:29 pm The process monitor worked! Here is the correct mpls for the Best Buy Blu Ray/DVD/Digital combo...
Title information
Name: John Wick 3: Parabellum (English)
Source file name: 00957.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
File name: John Wick 3- Parabellum_t369.mkv
Found this to be correct by manual correlation method. BluRay purchased at Walmart
Gojira74
#45 Post by Gojira74 » Wed Sep 11, 2019 5:49 am
Weird question, but did you watch the rest of the movie for 275 or did you stop after the library scene? If that was the only error in that section it would help to narrow it down in a manual way.
