John Wick: Chapter 3 - Parabellum
Mystic95z
Re: John Wick: Chapter 3 - Parabellum
Post by Mystic95z »
gamecaptor wrote: Tue Sep 10, 2019 4:27 pm Using Process Monitor on a RedBox disc I came back with 00965.mpls
Hmm, that doesn't match the RB disc I have as there isn't even a 00965.mpls on mine...
NeoCortex
Post by NeoCortex »
Mystic95z wrote: Tue Sep 10, 2019 6:30 pm
Same here. No 00965.mpls on my RB disc either.
debof14
Post by debof14 »
Yep thats the encryption working against you ...make sure you are on latest java install and make mkv version ... I see 965.mpls
blckz28
Post by blckz28 »
I just updated to 1.14.5 this morning and did the Java update suggest by debof14 but my mpls still jumps from 00964 to 00967 on a RB disk. I did try the Process Monitor filter and it showed to be using 00005 but this is the first time I tried finding mpls and don't entirely trust my findings.
FredT
Post by FredT »
debof14 wrote: Tue Sep 10, 2019 6:51 pm Yep thats the encryption working against you ...make sure you are on latest java install and make mkv version ... I see 965.mpls
I checked and have latest version of MakeMKV and Java. Still see 00964 and no 00965. Running on a Mac. Anything else to try?
dwgallone
Post by dwgallone »
Same thing here latest java and mkv I dont have 965 either
debof14
Post by debof14 »
towards the bottom of the list... click on the descriptions and on the right-hand side you will see the source file name. is about the 14th from the bottom. Still assuming that the correct one.
jeflatt
Post by jeflatt »
The process monitor worked! Here is the correct mpls for the Best Buy Blu Ray/DVD/Digital combo...
Title information
Name: John Wick 3: Parabellum (English)
Source file name: 00957.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
File name: John Wick 3- Parabellum_t369.mkv
FredT
Post by FredT »
debof14 wrote: Tue Sep 10, 2019 7:23 pm towards the bottom of the list... click on the descriptions and on the right-hand side you will see the source file name. is about the 14th from the bottom. Still assuming that the correct one.
Yes, 14th from the bottom:
Mystic95z
Post by Mystic95z »
Seriously doubt that. From process monitor the segment map from the disc I have is 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506 and matches up to 00429.mpls. Gotta wonder if they are now sending out RB discs with different obfuscation. But btw I do have latest versions of both....
Unibrowser
Post by Unibrowser »
I bought the 4k/1080p retail version today. I'm not sure if the titles that are (main feature) are correct. I seem to have very different playlists than other people. I'm most cases in the past the Main Feature listed one is correct. Can anyone confirm this?
http://imgur.com/gallery/mgNTLCo
This is the way
Mystic95z
Post by Mystic95z »
Unibrowser wrote: Tue Sep 10, 2019 8:31 pm I bought the 4k/1080p retail version today. I'm not sure if the titles that are (main feature) are correct. I seem to have very different playlists than other people. I'm most cases in the past the Main Feature listed one is correct. Can anyone confirm this?
Betting the main feature listed is NOT correct, have never seen one that is on one of these screen pass discs.
Sterling74
Post by Sterling74 »
Mystic95z wrote: Tue Sep 10, 2019 8:27 pm
Mystic95z - I agree with you too. I just finished scanning a RB disc to compare against the one I bought from Best Buy. The RB Blu-Ray disc is using 00429.mpls according to Proc Mon and that lines up with the order you have as well (510,511,502,505,512,501,519,516,508...). The RB disc did NOT have a playlist number 00965.
So, as of now, I think 00429 is the correct one for the disc I have.
Unibrowser
Mystic95z wrote: Tue Sep 10, 2019 8:37 pm
Hmmm. Well how do I go about figuring out which is correct? There is the one titled main feature and then like 200 other titles. So far the 300 movies I have ripped have been straightforward including the 4k movies. Although a few of the Disney disks have tried to throw me for a loop. Sorry I'm still a Makemkv noob. I updated to the latest version of Makemkv today, and Java is up to date as well.
This is the way
FredT
Post by FredT »
Sterling74 wrote: Tue Sep 10, 2019 8:42 pm Mystic95z - I agree with you too. I just finished scanning a RB disc to compare against the one I bought from Best Buy. The RB Blu-Ray disc is using 00429.mpls according to Proc Mon and that lines up with the order you have as well (510,511,502,505,512,501,519,516,508...). The RB disc did NOT have a playlist number 00965.
Thanks for that. The disk I have also has 00429, so I guess I'll go with that.
