BC-12D2HT flashed to BW-16D1HT 3.10
Verisurf
#1 Post by Verisurf » Sat Sep 07, 2019 12:52 am
I'm not sure what to do next? :D
Re: BC-12D2HT flashed to BW-16D1HT 3.10
#2 Post by Billycar11 » Sat Sep 07, 2019 1:25 am
Verisurf wrote: Sat Sep 07, 2019 12:52 am I'm not sure what to do next? :D
nothing just rip or play your disks
Verisurf
#3 Post by Verisurf » Sat Sep 07, 2019 12:29 pm
I apologize for not adding the other picture. I thought I was OK but it stopped ripping half way through. This was a 3 disk set from Wall Mart. 3D, Blue Ray, and UHD.
#4 Post by Woodstock » Sat Sep 07, 2019 2:28 pm
OK, I'd suggest cleaning the disk, even if it's new. In the If you're experiencing rip errors, please read here first! topic, there is a link to a site that describes recommended cleaning methods.
The log indicates that the drive found a section it couldn't read, and while it was trying to do so, the operating system decided the drive went "off-line". It wasn't, but Windows thought it was.
Verisurf
#5 Post by Verisurf » Sat Sep 07, 2019 11:19 pm
Another Error---different movie
#6 Post by MartyMcNuts » Sat Sep 07, 2019 11:39 pm
@Verisurf,
How is the drive connected to your computer? If externally, it may not be getting enough power.
Also, have you tried backing up the entire disc to FOLDER?
Verisurf
#7 Post by Verisurf » Sun Sep 08, 2019 2:47 am
Some added information. The read rate starts out high at over 17 M/s then is slows down and stops at Output size 4197.3 M.
I removed the Windows 10 Movie & TV app thinking it may be hindering the process but to no avail.
The disc drive was updated to version 11.0 before I started reading the forum. I was able to cross flash it to it's current configuration thanks to Mike's programing, your notes and others. I'm not that knowledgeable with computers. I think I just got lucky and did the right things. At least I thought so.
The drive is internal and connected to the Motherboard SATA port.
I don't understand how to copy to FOLDER? Can you explain?
On these attempts I have given a hard drive path to copy to.
#8 Post by MartyMcNuts » Sun Sep 08, 2019 3:11 am
Verisurf wrote: Sun Sep 08, 2019 2:47 am Some added information. The read rate starts out high at over 17 M/s then is slows down and stops at Output size 4197.3 M.
Ok. To decrypt the entire disc to folder, after you insert a disc and MakeMKV gathers the disc information, select the folder option (see green markings on picture). On the popup screen, make sure that decrypt content is checked and select a location to store the decrypted folder.
Verisurf
#9 Post by Verisurf » Sun Sep 08, 2019 3:20 pm
Understood. I'll give it a try and report back what happens. :)
Verisurf
#10 Post by Verisurf » Sun Sep 08, 2019 9:40 pm
:cry:
#11 Post by Billycar11 » Sun Sep 08, 2019 10:08 pm
Verisurf wrote: Sun Sep 08, 2019 9:40 pm
:cry:
probably a bad drive then
i know how it feels one time i got 3 in a row
exchange it
Verisurf
#12 Post by Verisurf » Sun Sep 08, 2019 11:38 pm
I would like to thank all whom have tried to help me. :D
What drive would you suggest?
Possibly the LG WH16NS60, UHD Official Internal 5.25 which is at the top of your list?
What do I flash it too when I get it installed to unlock UHD Reading/Ripping?
#13 Post by Billycar11 » Sun Sep 08, 2019 11:59 pm
Verisurf wrote: Sun Sep 08, 2019 11:38 pm I would like to thank all whom have tried to help me. :D
any of them could be defective but i do like the WH16NS60 the most but i have also gotten the most of those defective. 20+
Verisurf
#14 Post by Verisurf » Mon Sep 09, 2019 12:09 am
Do you think I would be better off choosing a different driver to lessen my chances of getting a defective one
If so, which ones would have less of a chance?
#15 Post by Billycar11 » Mon Sep 09, 2019 12:23 am
Verisurf wrote: Mon Sep 09, 2019 12:09 am Do you think I would be better off choosing a different driver to lessen my chances of getting a defective one
i have had no defective BU40N and WH16NS40s but those to are also the smallest sample size
the most out of box defective drives for me are WH16NS60 if you can look for drives built after 3/22/19
the 12/15/18-3/15/19 have an extremely high fail rate for those dates its like a 33%-50% fail
the rest are about the same fail rate
WH14NS40
asus BW-16D1HT
there is no reason to get a WH16NS60 unless you want official UHD playback
i would say get a WH14NS40 NS50 and flash it to NS60 to fix the sleep bug
