makeMKV not allowing to save to spare drive
Deke1955
Post by Deke1955 » Fri Sep 06, 2019 9:16 am
I've been using the program successfully for a short while but, since changing from Linux Mint to Ubuntu Mate the program has difficulty in allowing me to save as follows; if I rip a disc and then select titles to save I get the following error message,
"The size of output file '/media/deke/Toshiba_320/Videos/title_t00.mkv' may reach as much as 21375 megabytes while target filesystem has a file size limit of 4095 megabytes. Do you still want to continue (title will be skipped)?"
If I continue, it seems to save a title with nothing in it which takes seconds to do. So, the job is not carried out.
This destination is a USB controlled spare disc that I have fitted to my laptop for just such a job. Other operations with other programs have not had a fault. Is it perhaps something to do with the original formatting of the disc?
Thanks in advance.
Re: makeMKV not allowing to save to spare drive
Post by Woodstock » Fri Sep 06, 2019 12:59 pm
If the drive is formatted with FAT32, then it won't allow large files.
