John Wick: Chapter 3 - Parabellum
Steveredrum
Post by Steveredrum » Fri Sep 06, 2019 1:32 am
John Wick: Chapter 3 - Parabellum [U.S.A.RETAIL]
Does anyone know the PLAYLIST (MPLS - Screen Pass) please
hvnphoto
Re: John Wick: Chapter 3 - Parabellum
Post by hvnphoto » Fri Sep 06, 2019 5:13 am
Title information
Name: John Wick 3: Parabellum
Source file name: 00444.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t180.mkv
Steveredrum
Post by Steveredrum » Fri Sep 06, 2019 5:43 am
hvnphoto wrote: Fri Sep 06, 2019 5:13 am Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Thanks for your quick reply - Your a star again!
mgadbois
Post by mgadbois » Fri Sep 06, 2019 3:50 pm
I have a different information for 444.mpls. Mine is not the retail version though....
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,517,502,506,505,511,516,508,519,520,503,512,510,504,507,518,509,515,501
File name: John Wick 3- Parabellum_t184.mkv
Any help on getting the correct source file number is greatly appreciated.
ChrisCaPWN
Post by ChrisCaPWN » Sun Sep 08, 2019 9:28 pm
I ran the non-retail disc through process monitoring and found the following:
11:52:47.3516619 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00514.m2ts SUCCESS
11:53:17.5180367 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00514.m2ts SUCCESS
11:53:18.2570783 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00506.m2ts SUCCESS
11:53:19.2421264 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00517.m2ts SUCCESS
11:53:20.1311038 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00502.m2ts SUCCESS
11:53:51.1100072 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00505.m2ts SUCCESS
11:53:51.9089907 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00511.m2ts SUCCESS
11:53:52.6419816 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00508.m2ts SUCCESS
11:53:53.4663991 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00516.m2ts SUCCESS
11:54:29.9001658 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00519.m2ts SUCCESS
11:54:30.4432137 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00503.m2ts SUCCESS
11:54:31.2392217 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00520.m2ts SUCCESS
11:55:03.4070771 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00512.m2ts SUCCESS
11:55:05.2702759 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00510.m2ts SUCCESS
11:55:06.0503102 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00507.m2ts SUCCESS
11:55:06.8564019 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00504.m2ts SUCCESS
11:55:41.0622041 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00518.m2ts SUCCESS
11:55:41.7786088 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00509.m2ts SUCCESS
11:55:42.4114938 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00515.m2ts SUCCESS
11:57:11.1904888 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00501.m2ts SUCCESS
The disc loads with source file name: 00434.mpls listed as the main feature
John Wick 3: Parabellum - 16 chapter(s) , 32.0 GB (FPL_MainFeature)
Title information
Comment: FPL_MainFeature
Source file name: 00434.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,502,517,506,505,511,508,516,519,503,520,512,510,504,507,518,509,515,501
File name: John Wick 3- Parabellum-FPL_MainFeature_t00.mkv
However, I went through the disc line by line to find the correct segment map, and found 965 to be correct.
Title information
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t380.mkv
I'm not sure why 00434.mpls was tagged as the main feature...
Hopefully this helps those looking for the non-retail version.
Cheers,
-Chris
jeflatt
Post by jeflatt » Mon Sep 09, 2019 7:41 pm
I just received my copy from Best Buy (blu-ray, dvd, digital combo) and my mpls's don't match any listed here. This is what I have for 444.mpls:
Title information
Name: John Wick 3: Parabellum (English)
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,520,506,511,516,501,505,504,502,507,519,508,503,509,517
File name: John Wick 3- Parabellum_t168.mkv
Anyone know which playlist is correct for this versioin?
BobbyD1891
Post by BobbyD1891 » Tue Sep 10, 2019 1:24 am
jeflatt wrote: Mon Sep 09, 2019 7:41 pm I just received my copy from Best Buy (blu-ray, dvd, digital combo) and my mpls's don't match any listed here. This is what I have for 444.mpls:
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
I got the best buy verison as well and need help with this!
bretb
Post by bretb » Tue Sep 10, 2019 9:18 am
Can anyone confirm RdBx version? The stream I have doesn't appear to be correct.
gamecaptor
Post by gamecaptor » Tue Sep 10, 2019 4:27 pm
Using Process Monitor on a RedBox disc I came back with 00965.mpls
knyght1
Post by knyght1 » Tue Sep 10, 2019 4:33 pm
What is process monitor? How do you use it?
If you used an incorrect MPLS with handbrake what would be the result?
dp5081
Post by dp5081 » Tue Sep 10, 2019 4:50 pm
i'm getting corrupt or invalid offset,#numbers, attempting work around
gamecaptor
Post by gamecaptor » Tue Sep 10, 2019 4:52 pm
*sigh* Google?
https://www.youtube.com/watch?v=AlhBmIbReao
Your movie will be playing parts out of order.
jeflatt
Post by jeflatt » Tue Sep 10, 2019 5:20 pm
gamecaptor wrote: Tue Sep 10, 2019 4:52 pm *sigh* Google?
Well I'm going to certainly try that out when I get home. If it works, I'll post the results.
fredt2
Post by fredt2 » Tue Sep 10, 2019 5:21 pm
gamecaptor wrote: Tue Sep 10, 2019 4:27 pm Using Process Monitor on a RedBox disc I came back with 00965.mpls
My Redbox disc doesn't have 00965.mpls file. It 964 the 967. :?:
dwgallone
Post by dwgallone » Tue Sep 10, 2019 5:58 pm
I have redbox version there is no 965 need help
