John Wick: Chapter 3 - Parabellum
John Wick: Chapter 3 - Parabellum [U.S.A.RETAIL]
Does anyone know the PLAYLIST (MPLS - Screen Pass) please
Re: John Wick: Chapter 3 - Parabellum
Title information
Name: John Wick 3: Parabellum
Source file name: 00444.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t180.mkv
Duration: 2:10:45
Chapters count: 16
Segment count: 19
hvnphoto wrote: ↑Fri Sep 06, 2019 5:13 amTitle information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Thanks for your quick reply - Your a star again!
I have a different information for 444.mpls. Mine is not the retail version though....
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,517,502,506,505,511,516,508,519,520,503,512,510,504,507,518,509,515,501
File name: John Wick 3- Parabellum_t184.mkv
Any help on getting the correct source file number is greatly appreciated.
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
I ran the non-retail disc through process monitoring and found the following:
The disc loads with source file name: 00434.mpls listed as the main feature
However, I went through the disc line by line to find the correct segment map, and found 965 to be correct.
I'm not sure why 00434.mpls was tagged as the main feature...
Hopefully this helps those looking for the non-retail version.
Cheers,
-Chris
11:52:47.3516619 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00514.m2ts SUCCESS
11:53:17.5180367 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00514.m2ts SUCCESS
11:53:18.2570783 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00506.m2ts SUCCESS
11:53:19.2421264 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00517.m2ts SUCCESS
11:53:20.1311038 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00502.m2ts SUCCESS
11:53:51.1100072 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00505.m2ts SUCCESS
11:53:51.9089907 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00511.m2ts SUCCESS
11:53:52.6419816 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00508.m2ts SUCCESS
11:53:53.4663991 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00516.m2ts SUCCESS
11:54:29.9001658 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00519.m2ts SUCCESS
11:54:30.4432137 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00503.m2ts SUCCESS
11:54:31.2392217 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00520.m2ts SUCCESS
11:55:03.4070771 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00512.m2ts SUCCESS
11:55:05.2702759 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00510.m2ts SUCCESS
11:55:06.0503102 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00507.m2ts SUCCESS
11:55:06.8564019 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00504.m2ts SUCCESS
11:55:41.0622041 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00518.m2ts SUCCESS
11:55:41.7786088 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00509.m2ts SUCCESS
11:55:42.4114938 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00515.m2ts SUCCESS
11:57:11.1904888 AM PowerDVDMovie.exe 4444 CloseFile E:\BDMV\STREAM\00501.m2ts SUCCESS
John Wick 3: Parabellum - 16 chapter(s) , 32.0 GB (FPL_MainFeature)
Title information
Comment: FPL_MainFeature
Source file name: 00434.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,502,517,506,505,511,508,516,519,503,520,512,510,504,507,518,509,515,501
File name: John Wick 3- Parabellum-FPL_MainFeature_t00.mkv
Title information
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t380.mkv
Cheers,
-Chris
I just received my copy from Best Buy (blu-ray, dvd, digital combo) and my mpls's don't match any listed here. This is what I have for 444.mpls:
Title information
Name: John Wick 3: Parabellum (English)
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 518,512,514,510,515,520,506,511,516,501,505,504,502,507,519,508,503,509,517
File name: John Wick 3- Parabellum_t168.mkv
Anyone know which playlist is correct for this versioin?
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
I got the best buy verison as well and need help with this!jeflatt wrote: ↑Mon Sep 09, 2019 7:41 pmI just received my copy from Best Buy (blu-ray, dvd, digital combo) and my mpls's don't match any listed here. This is what I have for 444.mpls:
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Can anyone confirm RdBx version? The stream I have doesn't appear to be correct.
Using Process Monitor on a RedBox disc I came back with 00965.mpls
What is process monitor? How do you use it?
If you used an incorrect MPLS with handbrake what would be the result?
i'm getting corrupt or invalid offset,#numbers, attempting work around
*sigh* Google?
https://www.youtube.com/watch?v=AlhBmIbReao
Your movie will be playing parts out of order.
Well I'm going to certainly try that out when I get home. If it works, I'll post the results.gamecaptor wrote: ↑Tue Sep 10, 2019 4:52 pm*sigh* Google?
My Redbox disc doesn't have 00965.mpls file. It 964 the 967.gamecaptor wrote: ↑Tue Sep 10, 2019 4:27 pmUsing Process Monitor on a RedBox disc I came back with 00965.mpls
I have redbox version there is no 965 need help
