MIB International
MIB International
Has anyone successfully ripped MIB International? I have a retail version and am getting a notification that the volume key is unknown. This is the UHD retail version.
Re: MIB International
"If a disk key is not known then protected disc will fail to open. MakeMKV will save a disc dump in this case, called "AACS dump". Please send these dumps to svq@makemkv.com ."
Thanks - I wasn’t aware of this process. I’ve sent the file.d00zah wrote: ↑Tue Sep 03, 2019 4:11 pm"If a disk key is not known then protected disc will fail to open. MakeMKV will save a disc dump in this case, called "AACS dump". Please send these dumps to svq@makemkv.com ."
Many of the UHD BD processes and related errors/warnings have been discussed thoroughly already.
Forum search function can easily provide the solutions to these more often than not:
https://www.makemkv.com/forum/search.ph ... unknown%27
I have the best buy 4k UHD disk and it identified it ok. It is the regular 4k disk (not sure if they have others).
It found 3 tracks. Not sure what the difference is but two are the same size 45.1 GB and the last one being 33.4 GB.
midnighwatcher
Mine worked first try.
Mine is working now too. This was the first time I’d run into the key not being available in a very long time, and the first time ever on a UHD disc. If I run into again I will know what to do and just post once the dump file has been sent.
