MIB International
SeaWolf
MIB International
Post by SeaWolf » Tue Sep 03, 2019 4:03 pm
Has anyone successfully ripped MIB International? I have a retail version and am getting a notification that the volume key is unknown. This is the UHD retail version.
Re: MIB International
Post by d00zah » Tue Sep 03, 2019 4:11 pm
SeaWolf wrote: Tue Sep 03, 2019 4:03 pm Has anyone successfully ripped MIB International? I have a retail version and am getting a notification that the volume key is unknown. This is the UHD retail version.
"If a disk key is not known then protected disc will fail to open. MakeMKV will save a disc dump in this case, called "AACS dump". Please send these dumps to svq@makemkv.com ."
SeaWolf
Post by SeaWolf » Tue Sep 03, 2019 4:27 pm
d00zah wrote: Tue Sep 03, 2019 4:11 pm "If a disk key is not known then protected disc will fail to open. MakeMKV will save a disc dump in this case, called "AACS dump". Please send these dumps to svq@makemkv.com ."
Thanks - I wasn’t aware of this process. I’ve sent the file.
st4evr
Post by st4evr » Tue Sep 03, 2019 8:25 pm
Many of the UHD BD processes and related errors/warnings have been discussed thoroughly already.
Forum search function can easily provide the solutions to these more often than not:
https://www.makemkv.com/forum/search.ph ... unknown%27
saf001
Post by saf001 » Tue Sep 03, 2019 11:25 pm
I have the best buy 4k UHD disk and it identified it ok. It is the regular 4k disk (not sure if they have others).
It found 3 tracks. Not sure what the difference is but two are the same size 45.1 GB and the last one being 33.4 GB.
midnighwatcher
Post by midnighwatcher » Wed Sep 04, 2019 3:13 am
Mine worked first try.
SeaWolf
Post by SeaWolf » Wed Sep 04, 2019 10:33 am
Mine is working now too. This was the first time I’d run into the key not being available in a very long time, and the first time ever on a UHD disc. If I run into again I will know what to do and just post once the dump file has been sent.
