MakeMKV 1.14.4 to old?
thermalz
Post by thermalz » Tue Sep 03, 2019 12:44 pm
Hi went to use makemkv today and it says the 1.14.4 version is to old.
Is there an update soon?
Re: MakeMKV 1.14.4 to old?
Post by Woodstock » Tue Sep 03, 2019 1:13 pm
No, the next update is still "beyond the boundary", so to speak.
However, you can work around the issue by re-installing the beta key, found here, which should reset the "oldness timer".
gadgetHead
Post by gadgetHead » Tue Sep 03, 2019 9:07 pm
Where do I place the beta key?
TirusR
Post by TirusR » Tue Sep 03, 2019 10:42 pm
I had this problem too. Thanks for the fix.
Post by Woodstock » Wed Sep 04, 2019 1:54 am
Help->Register is where you enter keys, including the beta key. This also resets the 30-day timer for Bluray features.
