Trying to use MakeMKV 1.6 causes freezing of computer. Error Log:
Debug log started at Tue Sep 21 22:35:44 2010 , written by MakeMKV v1.6.0 win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.6.0 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\dtblair/MakeMKV_log.txt
003006:0000 Opening files on harddrive at M:/CD Music/Eagles/Hell Freezes Over/
003028:0000 Title #0 was added (22 cell(s), 1:38:29)
005014:0000 Saving 1 titles into directory D:/Video/(Fab7062)
001003:0020 DEBUG: Code 18018000 at .s#s#O$v2&91:,P`3-c:213129984
Same error repeats as program becomes unresponsive
Eagles Hell Freezes OVer
setarip_old
Re: Eagles Hell Freezes OVer
Hi!
Try re-ripping the original DVD using only MakeMKV...003006:0000 Opening files on harddrive at M:/CD Music/Eagles/Hell Freezes Over/
I've tried that before. The problem is the LPCM track on the disk. If I remove it, it rips fine, if I include it it fails. DVDfab brings the whole thing over so if I want to play the DVD on 2 channel stereo, I can select the LPCM track. The problem is that I have to deal with the VOB files which I would prefer not to. MakeMKV fails on LPCM streams which I have duplicated on other concert DVDs. Previous versions of MakeMKV have gone through the rip process then failed at the end. 1.6 fails and freezes immediately.
setarip_old
Cold comfort perhaps but, until this is resolved, the DTS audiostream for this DVD is quite acceptable (either played as DTS or downconverted to 2 channel stereo)...
- Contact:
Thanks for the info. What region is this disc?dtblair wrote:I've tried that before. The problem is the LPCM track on the disk. If I remove it, it rips fine, if I include it it fails. DVDfab brings the whole thing over so if I want to play the DVD on 2 channel stereo, I can select the LPCM track. The problem is that I have to deal with the VOB files which I would prefer not to. MakeMKV fails on LPCM streams which I have duplicated on other concert DVDs. Previous versions of MakeMKV have gone through the rip process then failed at the end. 1.6 fails and freezes immediately.
It's an all regions DVD
