yusesope
#586 Post by yusesope » Fri Aug 30, 2019 10:01 am
RESET_9999 wrote: Fri Aug 30, 2019 2:29 am triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.
I agree
Redhawk2000 wrote: Thu Aug 29, 2019 10:38 pm Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly?
Perhaps you'd be interested in the DTS-HD Master Audio format (DTS-HD MA == TrueHD). It's not freeware but, for "testing purpose" :wink: , it could be totally free.
Redhawk2000
#587 Post by Redhawk2000 » Fri Aug 30, 2019 4:03 pm
yusesope wrote: Fri Aug 30, 2019 10:01 amPerhaps you'd be interested in the DTS-HD Master Audio format (DTS-HD MA == TrueHD). It's not freeware but, for "testing purpose" :wink: , it could be totally free.
That would be just fine, actually. What would that option be?
yusesope
#588 Post by yusesope » Fri Aug 30, 2019 6:24 pm
Redhawk2000 wrote: Fri Aug 30, 2019 4:03 pm That would be just fine, actually. What would that option be?
What you need:
eac3to (search for "eac3to videohelp")
JAVA SE (search for "jPortable_6_Update_31.1_online.paf sourceforge")
DTS-HD Master Audio Suite (warez link removed)
DTS-HD Master Audio Suite is the tool you're looking for. In order for it to work, you have to install Java SE. I suggest you use the portable version (jPortable) and keep your PC clean. Run the paf.exe and select a destination directory (don't move the folder once created). You must also update the PATH environment variable by adding to it " the\directory\you\chose\Java\bin" (If you don't know how to do, search for "Add to the PATH on Windows 10").
Now, the first thing you must do is to convert your FLAC file to XX mono WAV tracks (where XX is the number of channels). The command line for that is:
eac3to input.flac output.wavs
Every wav will be renamed whit the correct channel label.
Once you have demuxed your original track, you must import the XX mono WAV tracks using DTS-HD Master Audio Suite. Choose the best settings and start the encoding process.
You're done!
mercwithamouth
#589 Post by mercwithamouth » Fri Aug 30, 2019 9:09 pm
mercwithamouth wrote: Thu Aug 29, 2019 9:02 pm I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
I do the same when a movie fit a BD-50 but almost all the movies are larger than that(even without all the audio and menu) and triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.
That is true, but if you have a large enough hard drive or USB, you could always burn a copy to it. It would only be the main movie, but special features typically aren't included on the 4K Blu-ray anyways, so you're not missing out on much.
omk1980
#590 Post by omk1980 » Sat Aug 31, 2019 6:20 am
For the time being, until more advances can be made, would you recommend backing up a decrypted copy of a DV uhd through make mkv or should I try and find out how to turn the disc to an iso file.
Silergo
#591 Post by Silergo » Sat Aug 31, 2019 7:22 pm
Finally found you, I have a question about you Dolby Vision creation guide on other forum, but can't pm you here. How can I contact you?
steffenmanden
#592 Post by steffenmanden » Sat Aug 31, 2019 8:52 pm
Awesome progress being made here!
Now we just need PGS support as well and it might actually make mkv the format of the past!
Really look forward to seeing the next steps
#593 Post by Woodstock » Sat Aug 31, 2019 9:26 pm
MP4 does NOT support PGS subtitles, period. The only reason it supports VOB subtitles is via "well supported" unofficial extension to the standard.
#594 Post by RESET_9999 » Sat Aug 31, 2019 10:07 pm
steffenmanden wrote: Sat Aug 31, 2019 8:52 pm Awesome progress being made here!
you can add subtitles in srt. format.
play fine on my TV but not with the bluray player.
mp4box.exe -add X:\DV.mp4:rate=0 -add X:\lpcm.mov#audio:lang=en-EN -add X:\en.srt#subtitle:lang=en-EN -add X:\fr.srt#subtitle:lang=fr-FR -tmp X:\ -brand mp42isom -ab dby1 -no-iod X:\DV.remux-7.1.mp4
Format : Timed Text
Codec ID : tx3g
Duration : 2 h 10 min
Bit rate mode : Variable
Bit rate : 32 b/s
Stream size : 30.2 KiB (0%)
Title : srt#subtitle:lang=en-EN@GPAC0.9.0-DEV-rev2671-g6d57ee94-filters
Language : English
Forced : No
steffenmanden
#595 Post by steffenmanden » Sun Sep 01, 2019 8:54 am
Woodstock wrote: Sat Aug 31, 2019 9:26 pm MP4 does NOT support PGS subtitles, period. The only reason it supports VOB subtitles is via "well supported" unofficial extension to the standard.
Wasn't this what people said about lossless audio also ? :)
steffenmanden
#596 Post by steffenmanden » Sun Sep 01, 2019 8:56 am
RESET_9999 wrote: Sat Aug 31, 2019 10:07 pm
Format : Timed Text
Codec ID : tx3g
Bit rate : 32 b/s
Language : English
Forced : No
Yea, that just makes a lot of extra work when ripping your own discs :) But i like the progress so far, we can't get it all
yusesope
#597 Post by yusesope » Sun Sep 01, 2019 11:16 am
Silergo wrote: Sat Aug 31, 2019 7:22 pm Finally found you, I have a question about you Dolby Vision creation guide on other forum, but can't pm you here. How can I contact you?
All right, you've found me. I surrender :lol: .
How can I help you?
You can write directly here, in this thread.
mercwithamouth wrote: Fri Aug 30, 2019 9:09 pm That is true, but if you have a large enough hard drive or USB, you could always burn a copy to it.
You just gave me an idea.
Instead of using a simple USB device, why not build a SMART USB device!
The new Raspberry pi 4 (like the old models A, A+ and Pi Zero) implements a USB (Type-C) On-The-Go (OTG. Official info HERE). It would thus be possible to connect devices that do not have the ability to use network protocols directly to a NAS/Server (Samba, NFS, etc...).
Another advantage could be that you don't have to wait two weeks before data transfer it's over (mechanical Hard Disk, slow USB 3.0 Transfer, etc...).
Some devices also do not allow playback of certain video/audio formats over DLNA; others may present bugs.
More information HERE and HERE (post number 10 is enlightening) in case anyone's interested.
I wish you all a good day!
Silergo
#598 Post by Silergo » Sun Sep 01, 2019 11:35 pm
yusesope wrote: Sun Sep 01, 2019 11:16 am All right, you've found me. I surrender :lol: .
How can I help you?
Ok, here's the thing: your test file (https://pcdn-my.pcloud.com/publink/show ... 5KfjfgGwOX) plays great on TV and Apple TV. But when I tried to create mine it hang the TV or even turn if off. I compared you file and mine so they'll be the same in MediaInfo, and also tried to play raw file just created from DVDfab (only used mp4box -splitx for videosample), but it doesn't work. Maybe I should change something in hex editor or something?
Here is my sample just in case: https://fex.net/s/losdyon
yusesope
#599 Post by yusesope » Mon Sep 02, 2019 10:13 am
Silergo wrote: Sun Sep 01, 2019 11:35 pm Ok, here's the thing: your test file (https://pcdn-my.pcloud.com/publink/show ... 5KfjfgGwOX) plays great on TV and Apple TV. But when I tried to create mine it hang the TV or even turn if off. I compared you file and mine so they'll be the same in MediaInfo, and also tried to play raw file just created from DVDfab (only used mp4box -splitx for videosample), but it doesn't work. Maybe I should change something in hex editor or something?
As you said, the two files are structurally "almost" identical.
I have edited your file to smooth out some minor differences.
You can find your modified video sample HERE.
I don't think that my my modification will changes anything (the differences were really minimal and negligible) but you should still try to play the file on your TV.
If it works, I'll explain what I've done.
Silergo
#600 Post by Silergo » Mon Sep 02, 2019 1:16 pm
yusesope wrote: Mon Sep 02, 2019 10:13 am I don't think that my my modification will changes anything (the differences were really minimal and negligible) but you should still try to play the file on your TV.
Yeah, unfortunately nothing changes. :( :(
Still don't understand, some people can play file and some don't (most of them have LG C8-C9). Even someone Sony UBP-X700 give green stripes. But Apple TV with infuse play this file with no problem. The only difference between our files is Mastering display luminance. Is it really give affect for playback?
