John Wick Chapter 2
Lovely Rita
Re: John Wick Chapter 2
Post by Lovely Rita » Sun Oct 15, 2017 9:15 pm
makeroflostsouls wrote:I see 440 has been listed as the correct file to copy. But my disk does not have this number listed. I have the blu-ray included in the 4k pack. Any one else have this issue? Thanks
Do you have the segment map: 502,508,501,514,506,503,505,515,513,512,504,507,511?
Registered User :wink:
Buy MakeMKV
Post by Woodstock » Sun Oct 15, 2017 11:22 pm
Make sure you check the top of the list - if MakeMKV thinks it found a match, it won't be in numerical order - it will be at the top.
makeroflostsouls
Post by makeroflostsouls » Mon Oct 16, 2017 7:09 pm
Woodstock wrote:Make sure you check the top of the list - if MakeMKV thinks it found a match, it won't be in numerical order - it will be at the top.
Thanks, never noticed that before..
Lovely Rita
Post by Lovely Rita » Mon Oct 16, 2017 10:06 pm
When this disc was first released the Java Runtime Engine did not list a Main Feature.
Whenever I run across a disc that does not I will forward Mike the required files (I'm sure others do the same) to help fine tune the JRE feature.
I just tried this disc again and it now DOES list a Main Feature (at the top, as Woodstock pointed out)
John Wick Chapter 2 - 16 Chapter(s), 33.8 GB (FPL_MainFeature)
Which turns out to be 440.mpls. :D
Buy MakeMKV
Wndsurfr
Post by Wndsurfr » Tue Oct 17, 2017 8:54 pm
Does anyone know why the Netflix version of the main feature (19.8GB) is almost half the size of the retail version (33.8GB)?
whymyname
Post by whymyname » Thu Jan 25, 2018 12:53 am
Resurrecting and hoping someone will see this.
I'm late to the game and read through the thread, my Netflix does not have 440 or 934. It does have 607, but I never read anywhere if that was correct?
preserve
Post by preserve » Thu Jan 25, 2018 1:22 am
Wndsurfr wrote:Does anyone know why the Netflix version of the main feature (19.8GB) is almost half the size of the retail version (33.8GB)?
Because they wanted to reduce costs and squeeze it onto a single layer disc?
Using: ASUS BW-16D1HT 3.00
daves_ale
Post by daves_ale » Mon Apr 29, 2019 10:43 pm
Bump, so the Netflix JW2 MPLS 934 is a bust. Matched up the maps and everything.
MPMS 440 does not exist. The only MPLS with a different time duration fails also (701).
Please help
SouperDeu2
Post by SouperDeu2 » Tue May 14, 2019 2:49 am
Please help
I'm using the "Back Again" version from RB and discovered that the very first full-length feature file listed shows 440. Odd, as I expected to find it chronologically. Doing the rip now and hoping for the best. 🤞
Post by Woodstock » Tue May 14, 2019 3:09 am
When MakeMKV recognizes the proper file (and it did for me on JW2), it moves it to the top of the list.
ixion
Post by ixion » Thu Aug 29, 2019 7:38 pm
After reading the entire thread, it seems like some people getting the disc from Redbox are getting a retail version of the disc (with TrueHD audio), this is not surprising, I have seen this with Netflilx as well, where I received a retail version while others reported getting a non-retail (you can usually tell by whether TrueHD is there or not).
Here is the consensus on this thread so far:
US Netflix (without TrueHD audio)
00934.mpls
Segment map: 502,505,512,504,516,515,513,506,509,510,514,518,511,501,520,503,519,508,507,517
US Retail (with TrueHD audio)
00440.mpls
Segment map: 502,508,501,514,506,503,505,515,513,512,504,507,511
US Redbox (with TrueHD audio, same as retail)
00440.mpls
oddeyeball
Post by oddeyeball » Mon Apr 06, 2020 7:33 pm
00440.mpls works with the steelbook 4k edition of john wick 1&2 from bestbuy.
MovieDude17
Post by MovieDude17 » Thu Sep 10, 2020 10:52 pm
unab0mb wrote:
Tue Jun 13, 2017 10:51 pm
Correct title for Netflix version:
Title information
Name: John Wick Chapter 2 (English)
Source file name: 00934.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 20
File name: John_Wick_Chapter_2_t369.mkv
I am verifying that this Segment Map is correct for the Netflix version, however my copy has file name John_Wick_Chapter_2_t371.mkv
I did verify the Segment Map by playing the MKV copy side by side the Blu Ray Disc and checking each scene
Thanks for providing the correct Segment Map and saving me tons of time : )
Manyfold
Post by Manyfold » Sun May 09, 2021 5:33 pm
Could anybody give a hint regarding the European / German version?
In this version, there are 37 .m2ts files. The one with the highest number is 00046.m2ts. Notably, there are no files from the 00500 range.
The only playlist which could be correct there is 00002.mpls, because this is the only one which includes 7.1 audio. It includes one segment, 00002.m2ts. So far, so good, but what worries me is the fact that its length is 02:03:03, while the correct length according to the statements in this thread should be 2:02:22. I suppose that they didn't add anything in the European / German version?
Any ideas?
Thanks a lot in advance!
realshadow
Post by realshadow » Fri Jan 21, 2022 6:00 pm
There was another disk in Canada starting with 514. Took me a day but I was able to figure it out. the right data is:
Title information
Source file name: 00796.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 13
Segment map: 514,501,503,502,511,504,515,505,513,508,507,506,512
File name: John_Wick_Chapter_2_t273.mkv
hope that helps someone.
