Chapter box default selection by application
wessongroup
Post by wessongroup » Thu Aug 29, 2019 12:58 pm
Is there any way to deselect ALL checked boxes for chapters
On some disks ALL boxes total over 200 + which must be deselected in order to process the data ... Or one is looking at 200 + chapters which in some cases total well over 6 thousand GB of data
Using a mac os .. The old standby "Select" then "shift click" at the last one does not work
Just looking for a mean to deselect ALL ... And then just use the "chapter" to transfer to a .mkv file which is then run through Handbrake to get the smaller .mp4 file.
No problems with your software ... works on all disks formats that I use
Thanks for any help
Grauhaar
Re: Chapter box default selection by application
Post by Grauhaar » Thu Aug 29, 2019 1:49 pm
Select a title, Click right and use deselect all
Good Luck :)
rui-no-onna
Post by rui-no-onna » Thu Aug 29, 2019 1:57 pm
I'm a bit confused as to what exactly you're referring to. If you meant the Title selection boxes in MakeMKV, right-click -> Unselect all works for me (Windows).
If you don't care for extras, you can limit what gets displayed based on length:
View -> Preferences -> Video -> Options: Minimum title length (seconds)
I tend to rip main video only so I have the minimum set to 600 (10 minutes). That gets rid of most of the cruft.
wessongroup
Post by wessongroup » Sat Aug 31, 2019 12:24 am
rui-no-onna wrote: Thu Aug 29, 2019 1:57 pm I'm a bit confused as to what exactly you're referring to. If you meant the Title selection boxes in MakeMKV, right-click -> Unselect all works for me (Windows).
Thanks ... "control click" for ma os ... worked fine ..
