Forced update to 1.6 now not working
replica9000
Re: Forced update to 1.6 now not working
#16 Post by replica9000 » Tue Sep 21, 2010 4:46 pm
1.6.1 fixed the problem for me. Also this version works without running it as root.
crowfax
#17 Post by crowfax » Tue Sep 21, 2010 5:37 pm
Thanks for the quick update Mike. Makes me glad I registered already!
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
kdemello
#18 Post by kdemello » Tue Sep 21, 2010 8:42 pm
The update fixed it for me too. I'm on my way to buy a key now!
crowfax
#19 Post by crowfax » Tue Sep 21, 2010 10:53 pm
kdemello wrote:The update fixed it for me too. I'm on my way to buy a key now!
Good call! :mrgreen:
BitJam2
#20 Post by BitJam2 » Fri Sep 24, 2010 9:41 am
It would be slightly easier for Gentoo users if you would bump the oss version number too even if the contents don't change. If the version numbers are consistent we just copy our installation file, create a digest and then install:
# cp makemkv-1.5.8.ebuild makemkv-1.6.1.ebuild
# ebuild makemkv-1.6.1.ebuild digest
# emerge makemkv
But since the oss version number wasn't bumped, the digest step failed because it couldn't download .../makemkv_v1.6.0_oss.tar.gz. I had to then figure out the problem and hard code "1.6.0" into the installation file in two places. So then next version change will require that I go back and edit the copied file once again to either get rid of or change the hard coded "1.6.0" (unless, of course, that file stays the same).
mwk1000
#21 Post by mwk1000 » Fri Sep 24, 2010 12:23 pm
Thank you, I see I was not alone!
