Apocalypse Now Final Cut
rdgrimes
Post by rdgrimes »
There are 2 UHD discs in this 6-disc set. (USA BB purchased)
One is the Final Cut, the other is "1979 / Redoux"
Neither is supported, files sent.
stuckinkodiagain
Re: Apocalypse Now Final Cut
Post by stuckinkodiagain »
rdgrimes wrote:
Tue Aug 27, 2019 9:24 pm
Also sent both dumps of the 2 UHD discs to svq@makemkv.com. Thanks to the developers as always!
hedcase
Post by hedcase »
Mine sent as well
thanks!
niteflyr
Post by niteflyr »
It's working now. Thanks Mike!
rdgrimes
Post by rdgrimes »
Yup, both discs are now working.
stuckinkodiagain
rdgrimes wrote:
Thu Aug 29, 2019 11:13 am
Does anyone know what the difference is between the two main feature options on the “Final Cut” UHD? I can’t tell. Any help would be appreciated!
Also, FYI, on the second UHD disc - which includes the Theatrical and Redux versions - there are 3 main feature playlists. The one with the shortest duration is the Theatrical Cut. Then there’s two longer playlists, both of which have the same duration. Those are for the “Redux” version.
Both “Redux” files are the same visually. However, one includes ONLY the film’s audio (nothing else), the second ONLY includes Coppola’s commentary track (and nothing else). I ripped both copies and then muxed all the audio together using MKVToolnix so that all of the audio options are available in one file.
rdgrimes
Post by rdgrimes »
stuckinkodiagain wrote:
Thu Aug 29, 2019 5:27 pm
There's an optional intro by F.F. Coppola, would that account for the extra play list? The menu options are "play with" and "play without".
stuckinkodiagain
rdgrimes wrote:
Fri Aug 30, 2019 2:13 am
Nope, I had ripped both versions and neither includes the intro. Also, both appear to have the same end credits sequence (both in English).
sajtipajti
Post by sajtipajti »
Hi!
I made an mkv from main movie of "Apocalypse Now The Final Cut" (relevant disc of 6 disc set) using the newest version of makemkv (1.15.2). The playlist of main movie points to two m2ts files, but the resulting mkv contains only th first one.
What is the solution?
TY in advance!
Edit
I gave it one more try: it seems to me that the program doesn't work with playlists.
This is BDinfo:
DISC INFO:
Disc Label: Apocalypse Now
Disc Size: 97,506,201,332 bytes
Length: 3:01:58.907
Name Time In Length Size Total Bitrate
00278.M2TS 0:00:00.000 2:55:51.123 0 0
00280.M2TS 2:55:51.123 0:06:07.784 0 0
Makemkv shows this:
Title information
Source file name: 00278.m2ts
Duration: 2:55:51
Segment count: 1
Segment map: 278
File name: title_t00.mkv
