Gladiator 4K UHD
djackson539
Gladiator 4K UHD
Post by djackson539 »
I bought this title a few weeks ago, found that MakeMKV didn't know the volume key, submitted the AACS dump to svq@makemkv.com (twice), and still no luck. I've ripped a few dozen discs so far and this is the only one that's been a problem.
st4evr
Re: Gladiator 4K UHD
Post by st4evr »
Read all of the advise in this similar thread:
https://www.makemkv.com/forum/viewtopic ... ort#p74720
And see if that helps.
djackson539
Well, with no further action on my part, I tried it again today and at long last it's decoding with the latest HK file. Interestingly, this disc has a much more complex structure than any of the others I've copied, with many titles and extensive seamless branching. I wonder if the long delay in the key's availability is related to this. In any case, thanks.
cabwiz
Post by cabwiz »
Hi, im new here and trying to figure out how to fix some ripping issues with 4k and hoping some experts can weigh in. I am using an ASUS drive that has been successful with multiple 4k rips, however, yesterday, Avengers Endgame failed and today i tried ripping Gladiator and it failed to rip with following errors:
MakeMKV v1.14.4 win(x64-release) started
The new version 1.14.7 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v05 id=96929CF53B04)
Saving 1 titles into directory F:/Video/Gladiator
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00506.m2ts' at offset '429735936'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00506.m2ts' at offset '447283200'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '447283200'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '447283200'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00506.m2ts' at offset '447283200'
Failed to save title 1 to file F:/Video/Gladiator/Gladiator_t01.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Thanks for any guidance!
Post by d00zah »
cabwiz wrote: Sun Jan 05, 2020 4:33 pm MakeMKV v1.14.4 win(x64-release) started
Typically a good idea to install the latest version & retry. If it still fails, repost the log.
cabwiz
Post by cabwiz »
yep, i updated to latest version 1.14.7 after reading the faqs and it failed again:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00522.m2ts' at offset '628205568'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '628205568'
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Post by d00zah »
cabwiz wrote: Sun Jan 05, 2020 7:09 pm Failed to save title 1 to file F:/Video/Gladiator/Gladiator_t01.mkv
I'd recommend giving the disc a good cleaning.
cabwiz
Post by cabwiz »
cleaned the disc thoroughly and still no luck, any other advice?
Post by d00zah »
Replace the disc?
"The ONLY reason for this error is inability of the drive to read the data from the disc. This is caused by a damaged disc, failing drive, or both. The error comes from the drive before MakeMKV has an opportunity to look at the data. Nothing else can cause this error - no protection, no software issue - only physical disc or drive damage."
Grauhaar
Post by Grauhaar »
There is a onther thread from you, which shows the same type of error:
Looking for help with this error while trying to rip Endgame:
Saving 1 titles into directory F:/Video/MARVEL'S AVENGERS- ENDGAME
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '29279907840'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '29279907840'
Failed to save title 0 to file F:/Video/MARVEL'S AVENGERS- ENDGAME/MARVEL'S AVENGERS- ENDGAME_t00.mkv
Sounds for me that the drive have a problem.
Good Luck :)
cabwiz
Post by cabwiz »
d00zah wrote: Tue Jan 07, 2020 1:15 pm Replace the disc?
Turns out it was a defective disc. Opened a new one and it worked on the first try. I will try this with Endgame as well, Thanks!
Post by d00zah »
Given the 2 options, disc or drive, the less expensive of the 2 seemed the wisest choice to try. Good luck with Endgame.
