Superman the Movie crashes MKV
kfreeb
Post by kfreeb »
For some reason this error report was also posted over in the DVD error report area, (not sure why it got posted there) but it should have been posted here.
I've done three rips of the Blu-ray movie, (Superman the Movie) with direct access mode enabled (errors out with "Internal error - Decryption error 411", which crashed MKV, (see crash report below.)
The disk is brand new. The optical surface is perfect, no scratches or fingerprints.
Here's the crash log:
Process: makemkvcon [2490]
Path: /Applications/makemkv_v1.5.8/MakeMKV.app/Contents/MacOS/makemkvcon
Identifier: makemkvcon
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: makemkv [2487]
Date/Time: 2010-09-16 13:08:57.989 -0600
OS Version: Mac OS X 10.6.4 (10F569)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000050c48368
Crashed Thread: 3
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x94275136 semaphore_wait_trap + 10
1 libSystem.B.dylib 0x942efbc3 pthread_join + 756
2 makemkvcon 0x0002b9f5 0x1000 + 174581
3 makemkvcon 0x000036a4 0x1000 + 9892
4 makemkvcon 0x000028c2 0x1000 + 6338
5 makemkvcon 0x000027e9 0x1000 + 6121
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x9429b942 kevent + 10
1 libSystem.B.dylib 0x9429c05c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9429b519 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9429b2be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9429ad41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9429ab86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x942eb22e sem_wait + 10
1 makemkvcon 0x0002c941 0x1000 + 178497
2 makemkvcon 0x0002b6c3 0x1000 + 173763
3 makemkvcon 0x0002baff 0x1000 + 174847
4 libSystem.B.dylib 0x942a281d _pthread_start + 345
5 libSystem.B.dylib 0x942a26a2 thread_start + 34
Thread 3 Crashed:
0 ??? 0xa0ac8fe2 typeinfo for __gnu_cxx::recursive_init_error + 6
1 libSystem.B.dylib 0x942e4138 _Unwind_GetRegionStart + 24
2 libstdc++.6.dylib 0x97f5fa9d parse_lsda_header(_Unwind_Context*, unsigned char const*, lsda_header_info*) + 29
3 libstdc++.6.dylib 0x97f5fda4 __gxx_personality_v0 + 150
4 libmakemkv.dylib 0x00448a44 HTTP_Download + 52020
5 libmakemkv.dylib 0x00448d50 HTTP_Download + 52800
6 libmakemkv.dylib 0x0043a4dd set_world + 13981
7 libmakemkv.dylib 0x0043adcc MkvCreateFile + 76
8 makemkvcon 0x0007aa03 0x1000 + 498179
9 makemkvcon 0x0000f536 0x1000 + 58678
10 makemkvcon 0x0003846b 0x1000 + 226411
11 makemkvcon 0x00038f7f 0x1000 + 229247
12 libSystem.B.dylib 0x942a281d _pthread_start + 345
13 libSystem.B.dylib 0x942a26a2 thread_start + 34
Thread 4:
1 makemkvcon 0x00039e14 0x1000 + 232980
2 makemkvcon 0x00038fa3 0x1000 + 229283
3 libSystem.B.dylib 0x942a281d _pthread_start + 345
4 libSystem.B.dylib 0x942a26a2 thread_start + 34
Thread 5:
Thread 6:
0 libSystem.B.dylib 0x94294086 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x98d7380d __CFSocketManager + 1085
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 3 crashed with X86 Thread State (32-bit):
eax: 0xb017f520 ebx: 0xb017f520 ecx: 0xb017f3a8 edx: 0xa0ac8fa8
edi: 0xb017f3a8 esi: 0xb017f2a7 ebp: 0xb017f288 esp: 0xb017f268
ss: 0x0000001f efl: 0x00010282 eip: 0xa0ac8fe2 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x50c48368
Binary Images:
0x1000 - 0x3e6fcb +makemkvcon ??? (???) <C3F9444F-4053-48F4-8796-364F063294CE> /Applications/makemkv_v1.5.8/MakeMKV.app/Contents/MacOS/makemkvcon
0x436000 - 0x495fc7 +libmakemkv.dylib ??? (???) <44C98F5C-E2DF-4AD9-93FB-E7B1236B175B> /Applications/makemkv_v1.5.8/MakeMKV.app/Contents/MacOS/libmakemkv.dylib
0x4b8000 - 0x4bbff5 +libdriveio.dylib ??? (???) /Applications/makemkv_v1.5.8/MakeMKV.app/Contents/MacOS/libdriveio.dylib
0x4bf000 - 0x574fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0x7c8000 - 0x7cdff7 com.apple.iokit.SCSITaskLib 2.6.5 (2.6.5) <0BC45C23-6FD2-C76E-4DCE-9C21F559AA50> /System/Library/Extensions/IOSCSIArchitectureModelFamily.kext/Contents/PlugIns/SCSITaskUserClient.kext/Contents/PlugIns/SCSITaskLib.plugin/Contents/MacOS/SCSITaskLib
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
0x90003000 - 0x90267fef com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x90278000 - 0x90285ff7 com.apple.NetFS 3.2.1 (3.2.1) <A6443845-5815-2429-7649-C51A4B5E7DF9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90e93000 - 0x90ec6ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x915f4000 - 0x91674feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91768000 - 0x917aeff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x91850000 - 0x91b70feb com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x91d95000 - 0x91dd9fe7 com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91ddb000 - 0x91e88fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x94274000 - 0x9441afeb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
0x9500e000 - 0x9504bff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9504c000 - 0x95116fef com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x95258000 - 0x952b3ff7 com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95610000 - 0x9561cff7 libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
0x962ca000 - 0x96373ff7 com.apple.CFNetwork 454.9.8 (454.9.<DB2A5C33-E833-1B3A-4DE0-5FF172B2048B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x963c6000 - 0x963ecfff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x97542000 - 0x97643fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x9781e000 - 0x97846ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x97afa000 - 0x97b03ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x97b04000 - 0x97c86fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
0x97d99000 - 0x97e36fe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x97f16000 - 0x97f80fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x988ad000 - 0x988adff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x989d3000 - 0x989e1fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
0x98c3d000 - 0x98cf6fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x98cf7000 - 0x98e71fe3 com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9945f000 - 0x99462fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9955d000 - 0x99571fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
2 x 3.46 GHz 6-Core Intel Xeon (mid 2012)
64GB Memory
Mac OS X 10.14.6
Re: Superman the Movie crashes MKV
Post by mike admin »
It's likely a bad disc. The next version will have better diagnostics.
kfreeb
Post by kfreeb »
Thanks Mike for replying.
I just downloaded the latest MKV update, (1.6.0) and it terminated the extract of "Superman the Movie", towards the end of the rip, at the same point as the previous version of MKV, (1.5.8) did.
Here's the log:
MakeMKV v1.5.8 darwin(x86-release) started
Optical drive "DVD+R-DL SONY DVD RW DW-D150A 1.MD" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in OS access mode.
Hit OS X IOSCSIMultimediaCommands bug, used type 0 workaround, see http://www.makemkv.com/osxbd/ for details.
File 00000.mpls was added as title #0
Title #00001.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #1
File 00006.m2ts was added as title #2
File 00007.m2ts was added as title #3
Title #00008.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #4
Operation sucessfully completed
Saving 1 titles into directory /Volumes/Blu-ray MKV's 2
Error 'Internal error - Decryption error (411)' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '15714226176'
Failed to save title 0 to file /Volumes/Blu-ray MKV's 2/title00.mkv
0 titles saved, 1 failed
64GB Memory
Mac OS X 10.14.6
kfreeb wrote:MakeMKV v1.5.8 darwin(x86-release) started
Can you please post a log from 1.6.0?
kfreeb
Post by kfreeb »
My Blu-ray drive is brand new, LG, Model: WG10LS30
Running Mac OS X 10.6.4
Here's the log from "Superman the Movie" rip, for MKV 1.6.0:
MakeMKV v1.6.0 darwin(x86-release) started
Saving 1 titles into directory /Users/kellyf/Desktop
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714220032, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714226176, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714232320, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714238464, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714244608, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714250752, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714256896, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714263040, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714269184, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714275328, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 15714281472, attempting to work around
Failed to save title 0 to file /Users/kellyf/Desktop/title00.mkv
64GB Memory
Mac OS X 10.14.6
Can you please back-up the disc with 1.6.0 and see if any hashcheck errors show up?
kfreeb
Post by kfreeb »
HI Mike
Ran the disk backup.
Dialog box said, "Backup done but 1 files failed hash check.
Here's the Log:
Backing up disc into folder "/Users/kellyf/Desktop/backup/LOGICAL_VOLUME_ID"
Hash check failed for file /BDMV/STREAM/00000.m2ts at offset 15714285568, file is corrupt.
Hash check failed for file /BDMV/STREAM/00000.m2ts at offset 24450758656, file is corrupt.
Hash check for /BDMV/STREAM/00000.m2ts : 0.00% corrupt, 99.99% correct, 99.99% checked.
64GB Memory
Mac OS X 10.14.6
Phredd
Post by Phredd »
I'm having the same problem with Deep Impact. First blu-ray since I upgraded to 1.6.0.
I tried to save Title 1 (29 chapters, 35.5 GB), but it failed. It complained that the 'mts' file is corrupt at many, many places. I don't think it is, because it plays fine.
The source file '/BDMV/STREAM/00052.m2ts' is corrupt or invalid at offset 18893125632, attempting to work around
The source file '/BDMV/STREAM/00052.m2ts' is corrupt or invalid at offset 18893764608, attempting to work around
Failed to save title 1 to file /Volumes/Media/title01.mkv
kfreeb wrote: Hash check failed for file /BDMV/STREAM/00000.m2ts at offset 15714285568, file is corrupt.
This absolutely positively irrevocably means that disc is physically scratched or damaged.
Phredd wrote:I'm having the same problem with Deep Impact. First blu-ray since I upgraded to 1.6.0.
Please do the same - back it up and see if any hashchek errors show up.
Phredd
Post by Phredd »
Yep, that's it. Thanks for the quick reply.
Hash check failed for file /BDMV/STREAM/00052.m2ts at offset 17803245568, file is corrupt.
Hash check failed for file /BDMV/STREAM/00052.m2ts at offset 17804425216, file is corrupt.
Hash check failed for file /BDMV/STREAM/00052.m2ts at offset 17810126848, file is corrupt.
Hash check failed for file /BDMV/STREAM/00052.m2ts at offset 17821530112, file is corrupt.
Hash check failed for file /BDMV/STREAM/00052.m2ts at offset 17822906368, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00052.m2ts.
Hash check for /BDMV/STREAM/00052.m2ts : 0.03% corrupt, 99.96% correct, 99.99% checked.
kfreeb
Post by kfreeb »
Hi Mike
I'm sure that the disk is not scratched, being that I have inspected the disk visually and that the disk is new. The disk plays fine beginning to end in the blue ray player, so as you said, it would appear that the data on the disk is recorded in such a way as to show up as damaged or corrupt.
So am I to then assume that I just will not be able to rip this disk ever?
64GB Memory
Mac OS X 10.14.6
Phredd
Post by Phredd »
kfreeb wrote: I'm sure that the disk is not scratched, being that I have inspected the disk visually and that the disk is new. The disk plays fine beginning to end in the blue ray player, so as you said, it would appear that the data on the disk is recorded in such a way as to show up as damaged or corrupt.
The latest form of copy protection?
[Update] I did have a disk that I bought new and looked perfect, but wouldn't play at all. Disney sent a replacement and it played fine on blu-ray and computer. I'm bringing my disk back for a replacement and I'll let you know if the problem persists.
[Update 2] I got a new Deep Impact and it works fine.
setarip_old
Post by setarip_old »
Return the disc to the place of purchase in exchange for a new replacement...
kfreeb
Post by kfreeb »
Returning the disk is not an option. It came from amazon.com and the window for returning the disk for a refund or replacement has come and gone.
64GB Memory
Mac OS X 10.14.6
