I'm getting the same result :( ... I'm still going to try it on the oled tonight...
EDIT:, nop, no go in the TV(which supports atmos and dts=x). no audio detected....
But it's still a step in the right direction. FFmpeg dev should be able to fix that.
MastaG
Post by MastaG »
RESET_9999 wrote: Mon Aug 26, 2019 6:47 pm I'm getting the same result :( ... im still going to try it on the oled tonight...
Please keep us posted :)
MastaG
Post by MastaG »
So I've compiled ffmpeg from git.
I now saved the truehd audio track from Alita to a new mp4 container.
Input #0, mpegts, from 'bluray:./':
  Duration: 00:03:28.21, start: 11.646667, bitrate: 2251891 kb/s
  Program 1
    Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0:1[0x1015]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0:2[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)
    Stream #0:3[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
It's the truehd one at 0:2.
So by simply doing:
ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 ../alita_demux/truehd.mp4
It will mux the truehd track into a "new" container:
Output #0, mp4, to '../alita_demux/truehd.mp4':
  Metadata:
    encoder         : Lavf58.31.104
    Stream #0:0: Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:2 -> #0:0 (copy)
Press [q] to stop, [?] for help
size= 4540858kB time=02:01:57.31 bitrate=5083.7kbits/s speed=14.2x
video:0kB audio:4506193kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.769282%
So now what?
I now use MP4Box to mux the truehd stream from the truehd.mp4 container into my DV mp4 container which I've created with dolby mp4muxer?
MastaG
Post by MastaG »
Well I tried to add the truehd track with MP4Box.
So for the record:
alita.dv.mp4 - The DV movie created with Dolby's mp4muxer (from the base-layer and enhanced-layer), only contains the two video layers
truehd.mp4 - The TrueHD audio track muxed into a mp4 container with ffmpeg: ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 truehd.mp4
dolby.ac3 - The Dolby Digital 5.1 audio track saved with ffmpeg: ffmpeg -i bluray:./ -map 0:3 -c copy dolby.ac3
MP4Box -add alita.dv.mp4:rate=0 -add truehd.mp4#audio:lang=en-US -add dolby.ac3#audio:lang=en-US -no-iod Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
IsoMedia import alita.dv.mp4 - track ID 1 - Video (size 3840 x 2160)
IsoMedia import alita.dv.mp4 - track ID 2 - Video (size 1920 x 1080)
[iso file] Unknown box type mlpa in parent stsd
IsoMedia import truehd.mp4 - track ID 1 - Audio (SR 0 - 2 channels)
AC3 import - sample rate 48000 - 5.1 channels
Saving to Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4: 0.500 secs Interleaving
I think MP4Box somehow messed up:
General
Complete name                            : Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
Format profile                           : Base Media
Codec ID                                 : isom (isom)
File size                                : 41.9 GiB
Duration                                 : 2 h 1 min
Overall bit rate                         : 49.2 Mb/s
Encoded date                             : UTC 2019-08-27 09:08:56
Tagged date                              : UTC 2019-08-27 09:08:56
Video #1
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 41.4 Mb/s
Bits/(Pixel*Frame)                       : 0.208
Stream size                              : 35.2 GiB (84%)
Encoded date                             : UTC 2019-08-08 13:26:09
Tagged date                              : UTC 2019-08-27 09:20:15
Maximum Content Light Level              : 233 cd/m2
Maximum Frame-Average Light Level        : 63 cd/m2
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 2 135 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.043
Stream size                              : 1.82 GiB (4%)
Audio #1
Format                                   : mlpa
Codec ID                                 : mlpa
Bit rate                                 : 5 045 kb/s
Maximum bit rate                         : 9 828 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 158 kHz
Bit depth                                : 16 bits
Stream size                              : 4.30 GiB (10%)
Audio #2
Codec ID                                 : ac-3
Maximum bit rate                         : 676 kb/s
Bit depth                                : 16 bits
Stream size                              : 558 MiB (1%)
Title                                    : ac3#audio:lang=en-US@GPAC0.8.0-revrelease
Encoded date                             : UTC 2019-08-27 09:20:14
As it reports the truehd (mlpa) track as 2-channels instead of 7.1
EDIT:
Here's the information regarding the truehd.mp4 container which contains the truehd track:
General
Complete name                            : truehd.mp4
Codec ID                                 : isom (isom/iso2/mp41)
File size                                : 4.33 GiB
Overall bit rate                         : 5 084 kb/s
Writing application                      : Lavf58.31.104
Audio
Format                                   : mlpa
Codec ID                                 : mlpa
Bit depth                                : 16 bits
Stream size                              : 4.30 GiB (99%)
So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
bl4ck
Post by bl4ck »
@MastaG
What linux you use? maybe you can help me compile dlb_mp4base
I use 4.19.66-1-MANJARO x86_64 GNU/Linux and my error:
linux_amd64]$ make mp4muxer_release
make: *** Brak reguł do zrobienia obiektu '../../../../dlb_mp4base/frontend/mp4_muxer_app.c', wymaganego przez 'obj/mp4muxer_release/mp4_muxer_app.o'. Stop.
yusesope
Post by yusesope »
bl4ck wrote: Wed Aug 28, 2019 11:28 am @MastaG
Did you run the "make" command inside the appropriate directory?
git clone https://github.com/DolbyLaboratories/dlb_mp4base.git
cd dlb_mp4base/make/mp4muxer/linux_amd64
bl4ck
Post by bl4ck »
Yep I tried git clone again now it is ok, thx.
yusesope
Post by yusesope »
bl4ck wrote: Wed Aug 28, 2019 3:40 pm Yep I tried git clone again now it is ok, thx.
You're welcome!
MastaG wrote: Tue Aug 27, 2019 9:42 am So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
A_TRUEHD is a codec tag used for the matroska container. I think the MPLA id is the right one. I don't know if out there there is a player that can start playing an audio track with this codec descriptor: if a device (like ours TVs) is unable to do so, it will need a firmware update (don't worry...it won't happen).
It seems to me that we're stuck at the same point...
mercwithamouth
Post by mercwithamouth »
I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
Redhawk2000
Post by Redhawk2000 »
Just a lurker here just paying attention to see if this ever really works fully. Sorry to ask a quick hijacking question but I wonder if it might be answered by what is necessary in the efforts of those trying to figure this out: Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly? Obviously wouldn't have Atmos metadata. Thanks.
mercwithamouth wrote: Thu Aug 29, 2019 9:02 pm I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
I do the same when a movie fit a BD-50 but almost all the movies are larger than that(even without all the audio and menu) and triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.
Redhawk2000 wrote: Thu Aug 29, 2019 10:38 pm Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly?
Freeware, no. Dolby TrueHD is proprietary, and there is no current free alternative to buying a license from Dolby.
yusesope
Post by yusesope »
RESET_9999 wrote: Fri Aug 30, 2019 2:29 am triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.
I agree
Perhaps you'd be interested in the DTS-HD Master Audio format (DTS-HD MA == TrueHD). It's not freeware but, for "testing purpose" :wink: , it could be totally free.
Redhawk2000
yusesope wrote: Fri Aug 30, 2019 10:01 amPerhaps you'd be interested in the DTS-HD Master Audio format (DTS-HD MA == TrueHD). It's not freeware but, for "testing purpose" :wink: , it could be totally free.
That would be just fine, actually. What would that option be?
yusesope
Post by yusesope »
Redhawk2000 wrote: Fri Aug 30, 2019 4:03 pm That would be just fine, actually. What would that option be?
What you need:
eac3to (search for "eac3to videohelp")
JAVA SE (search for "jPortable_6_Update_31.1_online.paf sourceforge")
DTS-HD Master Audio Suite (warez link removed)
DTS-HD Master Audio Suite is the tool you're looking for. In order for it to work, you have to install Java SE. I suggest you use the portable version (jPortable) and keep your PC clean. Run the paf.exe and select a destination directory (don't move the folder once created). You must also update the PATH environment variable by adding to it " the\directory\you\chose\Java\bin" (If you don't know how to do, search for "Add to the PATH on Windows 10").
Now, the first thing you must do is to convert your FLAC file to XX mono WAV tracks (where XX is the number of channels). The command line for that is:
eac3to input.flac output.wavs
Every wav will be renamed whit the correct channel label.
Once you have demuxed your original track, you must import the XX mono WAV tracks using DTS-HD Master Audio Suite. Choose the best settings and start the encoding process.
You're done!
