what to do with different angle of bluray?
gentoffer198
Post by gentoffer198 » Mon Aug 26, 2019 4:29 pm
when a bluray has many movie angles....how to make the mkv?
Re: what to do with different angle of bluray?
Post by Woodstock » Tue Aug 27, 2019 1:02 am
Each "angle" is a separate title; to make it into a single MKV file won't work so well. Generally, they're different language sets.
MakeMKV will offer to save each angle as its own MKV file, but it will not select all of them. You will have to do that manually.
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 8:13 am
Ok than you!
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 9:06 am
Woodstock wrote: Tue Aug 27, 2019 1:02 am Each "angle" is a separate title; to make it into a single MKV file won't work so well. Generally, they're different language sets.
What if the different angles were the same languages? What differences would we talk about?
Grauhaar
Post by Grauhaar » Thu Aug 29, 2019 11:09 am
Can be anything. Director's Cut, Credits in foreign languages, audio oder subtitles tracks .....
Good Luck :)
wmcclain
Post by wmcclain » Thu Aug 29, 2019 11:40 am
I have Ray Harryhausen discs where angle switches between the b&w and colorized versions.
On the 1960s Star Trek tv series, angle switches between the original and the updated effects versions.
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 1:10 pm
But it is very rare that the 8 angles have the same size, same languages ​​and all the same, up to the duration ...
Grauhaar wrote: Thu Aug 29, 2019 11:09 am Can be anything. Director's Cut, Credits in foreign languages, audio oder subtitles tracks .....
Grauhaar
Post by Grauhaar » Thu Aug 29, 2019 1:48 pm
Please post the MPLS stream segments of the 8 angels. Or check if they are the same, if yes, then the video is the same for all. If no, thre are some differences in the videos. To find it out, make a decrypted backup, go to the backup in the STREAM folder and view the different stream elements for the MPLS (Element = xxxxx.m2ts).
Good Luck :)
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 3:16 pm
Grauhaar wrote: Thu Aug 29, 2019 1:48 pm Please post the MPLS stream segments of the 8 angels. Or check if they are the same, if yes, then the video is the same for all. If no, thre are some differences in the videos. To find it out, make a decrypted backup, go to the backup in the STREAM folder and view the different stream elements for the MPLS (Element = xxxxx.m2ts).
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 3:23 pm
Grauhaar
Post by Grauhaar » Thu Aug 29, 2019 3:35 pm
Not helpfull at all.
You must click on each title and you see in the right windows of MakeMKV the MPLS (Playlist) Segment map 1,3,4,5,6,7,8 and so on.
Good Luck :)
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 4:10 pm
Grauhaar wrote: Thu Aug 29, 2019 3:35 pm Not helpfull at all.
if they change between angles, but then there are 7 versions of the same movie each of 22 gb? because the languages are the same and cannot be extra because the duration is the same, I will open the bluray to see if there are different angles.
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 4:19 pm
I don't see any possibility of different angles when viewing the bluray, I don't know what difference it opens ...
gentoffer198
Post by gentoffer198 » Thu Aug 29, 2019 4:24 pm
They are different languages in the credits ...... what a joke .... thanks for watching me.
