this is great news. let's hope yusesope can do his magic.likeadoc wrote: Sun Aug 25, 2019 4:07 pm Hey yusesope
my ffmpeg bug (https://trac.ffmpeg.org/ticket/8051) regarding implementation of a truehd substream just got closed with this commit http://git.videolan.org/?p=ffmpeg.git;a ... 7f4973d619 - TRUE HD ist now a supported format in the mp4 container!
Lets compile!!!!
Thanks for the update!likeadoc wrote: Sun Aug 25, 2019 4:07 pm Hey yusesope
I did a test using the "Amaze ATMOS" demo and compiling FFmpeg from the Git repository (master branch).
The following command allows you to mux the ATMOS track inside the mp4 container
ffmpeg.exe -i amaze.mkv -c copy -strict -2 amaze.mp4I could not play the audio of the file (neither on the PC using the latest LAV Filters nor on the TV).
ORIGINAL FILE (HERE)
Nome completo : amaze.mkv
Formato : Matroska
Versione formato : Version 4 / Version 2
Dimensione : 140MiB
Durata : 1 min 3s
Modo bitrate generale : Variabile
Bitrate totale : 18,4 Mb/s
Data codifica : UTC 2015-08-29 18:05:24
Creato con : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Compressore : libebml v1.3.1 + libmatroska v1.4.2
Video
Formato : AVC
Formato/Informazioni : Advanced Video Codec
Profilo formato : High@L4.1
Impostazioni formato, CABAC : Si
Impostazioni formato, ReFrames : 4 frame
ID codec : V_MPEG4/ISO/AVC
Durata : 1 min 3s
Modalità bitrate : Variabile
Bitrate : 11,7 Mb/s
Bitrate massimo : 40,0 Mb/s
Larghezza : 1.920 pixel
Altezza : 1.080 pixel
Rapporto aspetto visualizzazione : 16:9
Modalità frame rate : Costante
Frame rate : 24,000 FPS
Spazio colore : YUV
Croma subsampling : 4:2:0
Profondità bit : 8 bit
Tipo scansione : Progressivo
Bit/(pixel*frame) : 0.235
Dimensione della traccia : 88,4MiB (63%)
Lingua : Inglese
Default : Si
Forced : No
Audio
Formato : TrueHD
Profilo formato : TrueHD+Atmos / TrueHD
ID codec : A_TRUEHD
Durata : 1 min 3s
Bitrate : 6.694 kb/s
Bitrate massimo : 9.096 kb/s
Canali : Object Based / 8 canali
Posizione canali : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Frequenza campionamento : / 48,0 kHz
Frame rate : 1.200,000 FPS (40 spf)
Modo compressione : Senza perdita
Dimensione della traccia : 50,7MiB (36%)
Default : Si
Forced : NoCode: Select all
Nome completo : amaze.mp4
Formato : MPEG-4
Profilo formato : Base Media
ID codec : isom (isom/iso2/avc1/mp41)
Dimensione : 139MiB
Durata : 1 min 3s
Creato con : Lavf58.31.104
Video
Formato : AVC
ID codec : avc1
ID codec/Informazioni : Advanced Video Coding
Durata : 1 min 3s
Bitrate : 11,7 Mb/s
Modalità frame rate : Variabile
Frame rate minimo : 23,634 FPS
Frame rate massimo : 24,390 FPS
Spazio colore : YUV
Lingua : Inglese
Audio
Formato : mlpa
ID codec : mlpa
Durata : 1 min 3s
Canali : 2 canali
Frequenza campionamento : 0 Hz
Profondità bit : 16 bit
Default : Si
AlternateGroup/String : 1MP4Box recognizes the mlpa track and allows the mux inside the mp4 container but, as I said before, I can't play audio.
I'm getting the same result
... I'm still going to try it on the oled tonight...
EDIT:, nop, no go in the TV(which supports atmos and dts=x). no audio detected....
But it's still a step in the right direction. FFmpeg dev should be able to fix that.
Please keep us postedRESET_9999 wrote: Mon Aug 26, 2019 6:47 pm I'm getting the same result... im still going to try it on the oled tonight...
So I've compiled ffmpeg from git.
I now saved the truehd audio track from Alita to a new mp4 container.
It's the truehd one at 0:2.
So by simply doing:
It will mux the truehd track into a "new" container:
So now what?
I now use MP4Box to mux the truehd stream from the truehd.mp4 container into my DV mp4 container which I've created with dolby mp4muxer?
Input #0, mpegts, from 'bluray:./':
Duration: 00:03:28.21, start: 11.646667, bitrate: 2251891 kb/s
Program 1
Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
Stream #0:1[0x1015]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
Stream #0:2[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)
Stream #0:3[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
....So by simply doing:
ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 ../alita_demux/truehd.mp4Code: Select all
Output #0, mp4, to '../alita_demux/truehd.mp4':
Metadata:
encoder : Lavf58.31.104
Stream #0:0: Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
Stream #0:2 -> #0:0 (copy)
Press [q] to stop, [?] for help
size= 4540858kB time=02:01:57.31 bitrate=5083.7kbits/s speed=14.2x
video:0kB audio:4506193kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.769282%I now use MP4Box to mux the truehd stream from the truehd.mp4 container into my DV mp4 container which I've created with dolby mp4muxer?
Well I tried to add the truehd track with MP4Box.
So for the record:
alita.dv.mp4 - The DV movie created with Dolby's mp4muxer (from the base-layer and enhanced-layer), only contains the two video layers
truehd.mp4 - The TrueHD audio track muxed into a mp4 container with ffmpeg: ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 truehd.mp4
dolby.ac3 - The Dolby Digital 5.1 audio track saved with ffmpeg: ffmpeg -i bluray:./ -map 0:3 -c copy dolby.ac3
I think MP4Box somehow messed up:
As it reports the truehd (mlpa) track as 2-channels instead of 7.1
EDIT:
Here's the information regarding the truehd.mp4 container which contains the truehd track:
So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
So for the record:
MP4Box -add alita.dv.mp4:rate=0 -add truehd.mp4#audio:lang=en-US -add dolby.ac3#audio:lang=en-US -no-iod Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
IsoMedia import alita.dv.mp4 - track ID 1 - Video (size 3840 x 2160)
IsoMedia import alita.dv.mp4 - track ID 2 - Video (size 1920 x 1080)
[iso file] Unknown box type mlpa in parent stsd
IsoMedia import truehd.mp4 - track ID 1 - Audio (SR 0 - 2 channels)
AC3 import - sample rate 48000 - 5.1 channels
Saving to Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4: 0.500 secs InterleavingCode: Select all
General
Complete name : Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom)
File size : 41.9 GiB
Duration : 2 h 1 min
Overall bit rate : 49.2 Mb/s
Encoded date : UTC 2019-08-27 09:08:56
Tagged date : UTC 2019-08-27 09:08:56
Video #1
Format : HEVC
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 41.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.208
Stream size : 35.2 GiB (84%)
Default : No
Encoded date : UTC 2019-08-08 13:26:09
Tagged date : UTC 2019-08-27 09:20:15
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 233 cd/m2
Maximum Frame-Average Light Level : 63 cd/m2
Codec configuration box : hvcC
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 2 135 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.043
Stream size : 1.82 GiB (4%)
Default : No
Codec configuration box : hvcC+dvcC
Audio #1
Format : mlpa
Codec ID : mlpa
Bit rate : 5 045 kb/s
Maximum bit rate : 9 828 kb/s
Channel(s) : 2 channels
Sampling rate : 158 kHz
Bit depth : 16 bits
Stream size : 4.30 GiB (10%)
Language : English
Default : Yes
Alternate group : 1
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Maximum bit rate : 676 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 558 MiB (1%)
Title : ac3#audio:lang=en-US@GPAC0.8.0-revrelease
Language : English
Service kind : Complete Main
Encoded date : UTC 2019-08-27 09:20:14
Tagged date : UTC 2019-08-27 09:20:15EDIT:
General
Complete name : truehd.mp4
Format : MPEG-4
Codec ID : isom (isom/iso2/mp41)
File size : 4.33 GiB
Overall bit rate : 5 084 kb/s
Writing application : Lavf58.31.104
Audio
Format : mlpa
Codec ID : mlpa
Bit depth : 16 bits
Stream size : 4.30 GiB (99%)
Default : Yes
Alternate group : 1Re: Dolby Vision now possible through MP4 Mux.
@MastaG
What linux you use? maybe you can help me compile dlb_mp4base
I use 4.19.66-1-MANJARO x86_64 GNU/Linux and my error:
linux_amd64]$ make mp4muxer_release
make: *** Brak reguł do zrobienia obiektu '../../../../dlb_mp4base/frontend/mp4_muxer_app.c', wymaganego przez 'obj/mp4muxer_release/mp4_muxer_app.o'. Stop.
Did you run the "make" command inside the appropriate directory?bl4ck wrote: Wed Aug 28, 2019 11:28 am @MastaG
I use 4.19.66-1-MANJARO x86_64 GNU/Linux and my error:Code: Select all
linux_amd64]$ make mp4muxer_release make: *** Brak reguł do zrobienia obiektu '../../../../dlb_mp4base/frontend/mp4_muxer_app.c', wymaganego przez 'obj/mp4muxer_release/mp4_muxer_app.o'. Stop.
git clone https://github.com/DolbyLaboratories/dlb_mp4base.git
cd dlb_mp4base/make/mp4muxer/linux_amd64
Yep I tried git clone again now it is ok, thx.
You're welcome!
A_TRUEHD is a codec tag used for the matroska container. I think the MPLA id is the right one. I don't know if out there there is a player that can start playing an audio track with this codec descriptor: if a device (like ours TVs) is unable to do so, it will need a firmware update (don't worry...it won't happen).MastaG wrote: Tue Aug 27, 2019 9:42 am So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
It seems to me that we're stuck at the same point...
mercwithamouth
I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
- 20190829_161047.jpg (876.11 KiB) Viewed 40280 times
Redhawk2000
Just a lurker here just paying attention to see if this ever really works fully. Sorry to ask a quick hijacking question but I wonder if it might be answered by what is necessary in the efforts of those trying to figure this out: Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly? Obviously wouldn't have Atmos metadata. Thanks.
I do the same when a movie fit a BD-50 but almost all the movies are larger than that(even without all the audio and menu) and triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.mercwithamouth wrote: Thu Aug 29, 2019 9:02 pm I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
Freeware, no. Dolby TrueHD is proprietary, and there is no current free alternative to buying a license from Dolby.Redhawk2000 wrote: Thu Aug 29, 2019 10:38 pm Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly?
