#571 Post by RESET_9999 » Mon Aug 26, 2019 4:38 pm
likeadoc wrote: Sun Aug 25, 2019 4:07 pm Hey yusesope
my ffmpeg bug (https://trac.ffmpeg.org/ticket/8051) regarding implementation of a truehd substream just got closed with this commit http://git.videolan.org/?p=ffmpeg.git;a ... 7f4973d619 - TRUE HD ist now a supported format in the mp4 container!
this is great news. let's hope yusesope can do his magic.
MastaG
#572 Post by MastaG » Mon Aug 26, 2019 5:35 pm
Lets compile!!!!
yusesope
#573 Post by yusesope » Mon Aug 26, 2019 5:37 pm
Thanks for the update!
I did a test using the "Amaze ATMOS" demo and compiling FFmpeg from the Git repository (master branch).
The following command allows you to mux the ATMOS track inside the mp4 container
ffmpeg.exe -i amaze.mkv -c copy -strict -2 amaze.mp4
There seems to be some issue with the output (take a look at the mediainfo).
I could not play the audio of the file (neither on the PC using the latest LAV Filters nor on the TV).
ORIGINAL FILE (HERE)
Nome completo                           : amaze.mkv
Formato                                 : Matroska
Versione formato                        : Version 4 / Version 2
Dimensione                              : 140MiB
Durata                                  : 1 min 3s
Modo bitrate generale                   : Variabile
Bitrate totale                          : 18,4 Mb/s
Data codifica                           : UTC 2015-08-29 18:05:24
Creato con                              : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Compressore                             : libebml v1.3.1 + libmatroska v1.4.2
Video
Formato                                 : AVC
Formato/Informazioni                    : Advanced Video Codec
Profilo formato                         : High@L4.1
Impostazioni formato, CABAC             : Si
Impostazioni formato, ReFrames          : 4 frame
ID codec                                : V_MPEG4/ISO/AVC
Durata                                  : 1 min 3s
Modalità bitrate                        : Variabile
Bitrate                                 : 11,7 Mb/s
Bitrate massimo                         : 40,0 Mb/s
Larghezza                               : 1.920 pixel
Altezza                                 : 1.080 pixel
Rapporto aspetto visualizzazione        : 16:9
Modalità frame rate                     : Costante
Frame rate                              : 24,000 FPS
Spazio colore                           : YUV
Croma subsampling                       : 4:2:0
Profondità bit                          : 8 bit
Tipo scansione                          : Progressivo
Bit/(pixel*frame)                       : 0.235
Dimensione della traccia                : 88,4MiB (63%)
Lingua                                  : Inglese
Default                                 : Si
Forced                                  : No
Audio
Formato                                 : TrueHD
Profilo formato                         : TrueHD+Atmos / TrueHD
ID codec                                : A_TRUEHD
Durata                                  : 1 min 3s
Bitrate                                 : 6.694 kb/s
Bitrate massimo                         : 9.096 kb/s
Canali                                  : Object Based / 8 canali
Posizione canali                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Frequenza campionamento                 :  / 48,0 kHz
Frame rate                              : 1.200,000 FPS (40 spf)
Modo compressione                       : Senza perdita
Dimensione della traccia                : 50,7MiB (36%)
Default                                 : Si
Forced                                  : No
MP4 MUX (HERE)
Nome completo                           : amaze.mp4
Formato                                 : MPEG-4
Profilo formato                         : Base Media
ID codec                                : isom (isom/iso2/avc1/mp41)
Dimensione                              : 139MiB
Durata                                  : 1 min 3s
Creato con                              : Lavf58.31.104
Video
Formato                                 : AVC
ID codec                                : avc1
ID codec/Informazioni                   : Advanced Video Coding
Durata                                  : 1 min 3s
Bitrate                                 : 11,7 Mb/s
Modalità frame rate                     : Variabile
Frame rate minimo                       : 23,634 FPS
Frame rate massimo                      : 24,390 FPS
Spazio colore                           : YUV
Lingua                                  : Inglese
Audio
Formato                                 : mlpa
ID codec                                : mlpa
Durata                                  : 1 min 3s
Canali                                  : 2 canali
Frequenza campionamento                 : 0 Hz
Profondità bit                          : 16 bit
Default                                 : Si
AlternateGroup/String                   : 1
MP4Box recognizes the mlpa track and allows the mux inside the mp4 container but, as I said before, I can't play audio.
#574 Post by RESET_9999 » Mon Aug 26, 2019 6:47 pm
I'm getting the same result :( ... I'm still going to try it on the oled tonight...
EDIT:, nop, no go in the TV(which supports atmos and dts=x). no audio detected....
But it's still a step in the right direction. FFmpeg dev should be able to fix that.
MastaG
#575 Post by MastaG » Tue Aug 27, 2019 7:51 am
RESET_9999 wrote: Mon Aug 26, 2019 6:47 pm I'm getting the same result :( ... im still going to try it on the oled tonight...
Please keep us posted :)
MastaG
#576 Post by MastaG » Tue Aug 27, 2019 8:57 am
So I've compiled ffmpeg from git.
I now saved the truehd audio track from Alita to a new mp4 container.
Input #0, mpegts, from 'bluray:./':
  Duration: 00:03:28.21, start: 11.646667, bitrate: 2251891 kb/s
  Program 1
    Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0:1[0x1015]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0:2[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)
    Stream #0:3[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
It's the truehd one at 0:2.
So by simply doing:
ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 ../alita_demux/truehd.mp4
It will mux the truehd track into a "new" container:
Output #0, mp4, to '../alita_demux/truehd.mp4':
  Metadata:
    encoder         : Lavf58.31.104
    Stream #0:0: Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:2 -> #0:0 (copy)
Press [q] to stop, [?] for help
size= 4540858kB time=02:01:57.31 bitrate=5083.7kbits/s speed=14.2x
video:0kB audio:4506193kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.769282%
So now what?
I now use MP4Box to mux the truehd stream from the truehd.mp4 container into my DV mp4 container which I've created with dolby mp4muxer?
MastaG
#577 Post by MastaG » Tue Aug 27, 2019 9:42 am
Well I tried to add the truehd track with MP4Box.
So for the record:
alita.dv.mp4 - The DV movie created with Dolby's mp4muxer (from the base-layer and enhanced-layer), only contains the two video layers
truehd.mp4 - The TrueHD audio track muxed into a mp4 container with ffmpeg: ffmpeg -i bluray:./ -map 0:2 -c copy -strict -2 truehd.mp4
dolby.ac3 - The Dolby Digital 5.1 audio track saved with ffmpeg: ffmpeg -i bluray:./ -map 0:3 -c copy dolby.ac3
MP4Box -add alita.dv.mp4:rate=0 -add truehd.mp4#audio:lang=en-US -add dolby.ac3#audio:lang=en-US -no-iod Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
IsoMedia import alita.dv.mp4 - track ID 1 - Video (size 3840 x 2160)
IsoMedia import alita.dv.mp4 - track ID 2 - Video (size 1920 x 1080)
[iso file] Unknown box type mlpa in parent stsd
IsoMedia import truehd.mp4 - track ID 1 - Audio (SR 0 - 2 channels)
AC3 import - sample rate 48000 - 5.1 channels
Saving to Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4: 0.500 secs Interleaving
I think MP4Box somehow messed up:
General
Complete name                            : Alita.Battle.Angel.2019.DV.TrueHD.AC3.mp4
Format profile                           : Base Media
Codec ID                                 : isom (isom)
File size                                : 41.9 GiB
Duration                                 : 2 h 1 min
Overall bit rate                         : 49.2 Mb/s
Encoded date                             : UTC 2019-08-27 09:08:56
Tagged date                              : UTC 2019-08-27 09:08:56
Video #1
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 41.4 Mb/s
Bits/(Pixel*Frame)                       : 0.208
Stream size                              : 35.2 GiB (84%)
Encoded date                             : UTC 2019-08-08 13:26:09
Tagged date                              : UTC 2019-08-27 09:20:15
Maximum Content Light Level              : 233 cd/m2
Maximum Frame-Average Light Level        : 63 cd/m2
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 2 135 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.043
Stream size                              : 1.82 GiB (4%)
Audio #1
Format                                   : mlpa
Codec ID                                 : mlpa
Bit rate                                 : 5 045 kb/s
Maximum bit rate                         : 9 828 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 158 kHz
Bit depth                                : 16 bits
Stream size                              : 4.30 GiB (10%)
Audio #2
Codec ID                                 : ac-3
Maximum bit rate                         : 676 kb/s
Bit depth                                : 16 bits
Stream size                              : 558 MiB (1%)
Title                                    : ac3#audio:lang=en-US@GPAC0.8.0-revrelease
Encoded date                             : UTC 2019-08-27 09:20:14
As it reports the truehd (mlpa) track as 2-channels instead of 7.1
EDIT:
Here's the information regarding the truehd.mp4 container which contains the truehd track:
General
Complete name                            : truehd.mp4
Codec ID                                 : isom (isom/iso2/mp41)
File size                                : 4.33 GiB
Overall bit rate                         : 5 084 kb/s
Writing application                      : Lavf58.31.104
Audio
Format                                   : mlpa
Codec ID                                 : mlpa
Bit depth                                : 16 bits
Stream size                              : 4.30 GiB (99%)
So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
bl4ck
#578 Post by bl4ck » Wed Aug 28, 2019 11:28 am
@MastaG
What linux you use? maybe you can help me compile dlb_mp4base
I use 4.19.66-1-MANJARO x86_64 GNU/Linux and my error:
linux_amd64]$ make mp4muxer_release
make: *** Brak reguł do zrobienia obiektu '../../../../dlb_mp4base/frontend/mp4_muxer_app.c', wymaganego przez 'obj/mp4muxer_release/mp4_muxer_app.o'. Stop.
yusesope
#579 Post by yusesope » Wed Aug 28, 2019 3:28 pm
bl4ck wrote: Wed Aug 28, 2019 11:28 am @MastaG
Did you run the "make" command inside the appropriate directory?
git clone https://github.com/DolbyLaboratories/dlb_mp4base.git
cd dlb_mp4base/make/mp4muxer/linux_amd64
bl4ck
#580 Post by bl4ck » Wed Aug 28, 2019 3:40 pm
Yep I tried git clone again now it is ok, thx.
yusesope
#581 Post by yusesope » Wed Aug 28, 2019 4:03 pm
bl4ck wrote: Wed Aug 28, 2019 3:40 pm Yep I tried git clone again now it is ok, thx.
You're welcome!
MastaG wrote: Tue Aug 27, 2019 9:42 am So it looks like FFMpeg still needs some work as the codec ID should be: A_TRUEHD and it sohuld at least report 7.1 channels...
A_TRUEHD is a codec tag used for the matroska container. I think the MPLA id is the right one. I don't know if out there there is a player that can start playing an audio track with this codec descriptor: if a device (like ours TVs) is unable to do so, it will need a firmware update (don't worry...it won't happen).
It seems to me that we're stuck at the same point...
mercwithamouth
#582 Post by mercwithamouth » Thu Aug 29, 2019 9:02 pm
I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
Redhawk2000
#583 Post by Redhawk2000 » Thu Aug 29, 2019 10:38 pm
Just a lurker here just paying attention to see if this ever really works fully. Sorry to ask a quick hijacking question but I wonder if it might be answered by what is necessary in the efforts of those trying to figure this out: Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly? Obviously wouldn't have Atmos metadata. Thanks.
#584 Post by RESET_9999 » Fri Aug 30, 2019 2:29 am
mercwithamouth wrote: Thu Aug 29, 2019 9:02 pm I used DVDFab's UHD Copy to burn a movie file onto a blank Blu-ray disc yesterday and, as it turns out, it keeps the Dolby Vision AND the lossless Dolby Atmos track. I downloaded Rocketman (found an HEVC upload of it, which is the entire disc including Dolby Vision), and after burning a copy onto the blank disc, I played it on my Sony UBP-X700 Blu-ray player. Sure enough, this popped up. I have yet to test a rip of one of my 4K Blu-rays, but I'm sure it'll work roughly the same.
I do the same when a movie fit a BD-50 but almost all the movies are larger than that(even without all the audio and menu) and triple-layer BD-R are very expensive. yes, you can encode it to fit a BD-50 or even a BD-25 but it's not an option when you only want to watch the best quality possible.
#585 Post by Woodstock » Fri Aug 30, 2019 2:40 am
Redhawk2000 wrote: Thu Aug 29, 2019 10:38 pm Is it possible with freeware (or cheapware) to convert lpcm (actually flac) to Dolby true HD losslessly?
Freeware, no. Dolby TrueHD is proprietary, and there is no current free alternative to buying a license from Dolby.
