Asus BW-16D1HT 3.03
plumptree
Re: Asus BW-16D1HT 3.03
#46 Post by plumptree » Sun Aug 25, 2019 3:30 am
Hey, being the big dumb baby I am, I decided to install the latest update for the BW-16D1HT (3.10) and now realize that it isnt compatible with the libre drivers. Is there a way to flash the firmware and downgrade or am I going to have to exchange this bad boy at the Memory Express where I got it?
#47 Post by MartyMcNuts » Sun Aug 25, 2019 3:36 am
plumptree wrote: Sun Aug 25, 2019 3:30 am Hey, being the big dumb baby I am, I decided to install the latest update for the BW-16D1HT (3.10) and now realize that it isnt compatible with the libre drivers. Is there a way to flash the firmware and downgrade or am I going to have to exchange this bad boy at the Memory Express where I got it?
Yes, use the modified ASUS flasher to flash 3.10-mk.
You can then either use it with 3.10-mk or flash another firmware.
mostlife
#48 Post by mostlife » Sun Aug 25, 2019 8:18 pm
Is Windows 10 automatically updating 4K friendly drive firmware?
Or does Windows 10 only Install drivers and windows updates?
st4evr
#49 Post by st4evr » Sun Aug 25, 2019 10:03 pm
mostlife wrote: Sun Aug 25, 2019 8:18 pm Is Windows 10 automatically updating 4K friendly drive firmware?
When it comes to optical disc drives Windows has never and currently still does not execute these types of updates. This is why—as it’s very clearly discussed in this very thread—you need drive manufacturer specific software flashers (e.g ASUS, LG, etc) to update (and in many cases as discussed in this forum as well, downgrade) said firmware.
Aluminumhaste
#50 Post by Aluminumhaste » Thu Oct 07, 2021 10:21 pm
Sorry for old thread Becel but I have the same drive with same firmware, 3.03.
Every time I try to flash the DE3.02 firmware it the 3.10mk firmware, it said failed. Sense 00/00/00 or something like that, the message is cut off at the bottom.
Then after about a minute, the whole computer restarts. If I try to end the app, the computer restarts.
I thought it might be because I switched all my components to MSI instead of IRQ, so changed back and tried again, same problem.
Windows 10 latest version.
Ryzen 3900X
Asrock taichi X470
Any one else run into this?
#51 Post by Billycar11 » Thu Oct 07, 2021 11:19 pm
Aluminumhaste wrote: Thu Oct 07, 2021 10:21 pm Sorry for old thread Becel but I have the same drive with same firmware, 3.03.
Ryzen 3900X
Asrock taichi X470
Use the new guide linked below and then post there any errors you have
