COPY PROTECTION KEY EXCHANGE FAILURE
davewithheld
Post by davewithheld » Tue Sep 21, 2010 4:12 am
Didn't know if I should post to the Linux group, but... I'm having the exact same error(s) on a dual boot system; both fedora 12 (gnome) and Uubuntu 9.10 (kde). Build and install seemed to work fine on both OS's. Program runs fine but errors before I get a list of titles. It makes no difference if I run as root or normal user. Here's what I get:
#> makemkvcon backup --decrypt disc:0 /shome/video/bluray
MakeMKV v1.6.0 linux(x64-release) started
Backing up disc into folder "/shome/video/bluray"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
... many more of these same errors, then ...
Backup failed
Backup failed.
/shome/video/blueray was manually created before the command was issued. If I execute the same command without the --decrypt switch I get a copy (I assume encrypted) of the disk. I tried the GUI with "Log debug" turned on and got the same messages with these in between each occurrence:
Bluray Drive is an internal Plextor with current firmware. It plays in Windows XP with PowerDVD 8. Here is drive info (from wodim):
#> wodim -prcap dev=/dev/sr0
Device type : Removable CD-ROM
Version : 5
Response Format: 2
Capabilities :
Vendor_info : 'PLEXTOR '
Identification : 'BDDVDR PX-B310SA'
Revision : '1.06'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
As I said, I have tried fedora and ubuntu. I actually have a triple boot system with WinXP. I have not tried the Windows version of makemkv as I would really like to get it working on the fedora system. This is my first attempt at using makemkv on the movie Solitary Man. Any advice on how to proceed?
Re: COPY PROTECTION KEY EXCHANGE FAILURE
Post by mike admin » Tue Sep 21, 2010 7:56 am
A known problem with 64-bit linux version 1.6.0 . Please check back for an update.
