Question about ripping DolbyVision and playing it
Daskew78
Re: Question about ripping DolbyVision and playing it
Post by Daskew78 » Sat Aug 24, 2019 9:50 pm
Sorry I mean MP4!
I am just about to run it through CloneDB now but not sure what audio to select... which is best quality:
AAC Advanced Audio Codec?
Or
Dolby Digital AC3?
Regards
Dave
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 10:17 pm
SamuriHL wrote: Sat Aug 24, 2019 9:15 pm Woa woa woa. I never said CloneBD will keep the Dolby Vision video track in an MKV container. It most definitely WON'T. MakeMKV will but only if you use it to make the MKV. So this is not going to work.
Sorry I missed this.
So If I do a backup with MakeMKV, use CloneDB to identify what files to use and then use MakeMKV again to convert it into an MKV?
Does that sound right?
Regards
Dave
Post by SamuriHL » Sat Aug 24, 2019 10:31 pm
You could. It'll tell you which playlist to use.
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 10:38 pm
Yeah, I'm getting there now pal!
I did rip it initially but I'm thinking next time I can hopefully just read the disc with CloneDB (so I don't have to rip it twice), it will tell me the mpls number then when highlighting the tree in MakeMKV I can look for that mpls and that's the file I use? right?
It's making the MKV now using the method above now, I'll check it soon and my bro should be home any minute so I should be able to test it on his TV.
Regards
Dave
Post by SamuriHL » Sat Aug 24, 2019 10:45 pm
Um, no. You can't just rip it with CloneBD. Go back and re-read what I and woodstock said to you about this. It REQUIRES a decrypted source. A disc is NOT a decrypted source.
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 10:47 pm
I wasn't talking about ripping it with CloneBD, I was talking about READING it with CloneDB. I can't check now as it's running but will it not READ from the disc?
Regards
Dave
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 11:10 pm
Okay it finished burning and I tried and it said "nope". Still i backed up the correct file and I'm still not seeing the Dolby Vision in the MediaInfo... I can't work out what I'm doing wrong?
Regards
Dave
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 11:17 pm
For Alita - Battle Angel, I've back it up with MakeMKV... Opened the files in CloneBD and I thought the default file it selected was the one I backup in MakeMKV. Maybe that's where I'm going wrong?
How do I identify in CloneDB what the file to use in MakeMKV is please?
Regards
Dave
Daskew78
Post by Daskew78 » Sat Aug 24, 2019 11:38 pm
I give up, just can't work it out. There's 3 files which have Dolby Vision it says and they are all like 40 seconds, 50 seconds and 1 minute 40 seconds so none of them.
Thanks for all your help anyway :)
Regards
Dave
Post by SamuriHL » Sat Aug 24, 2019 11:50 pm
Daskew78 wrote: Sat Aug 24, 2019 10:47 pm I wasn't talking about ripping it with CloneBD, I was talking about READING it with CloneDB. I can't check now as it's running but will it not READ from the disc?
No, it CAN NOT open a protected source.
Post by SamuriHL » Sat Aug 24, 2019 11:52 pm
As for Alita select title 800 in MakeMKV and back that up. It might be wrong, but, I know that one has the Dolby Vision stuff. I have no idea what titles you've tried backing up so far but they seem wrong. CloneBD tells you what the titleset is when you check it on the selection screen. But do 800 and see what the MakeMKV made MKV looks like in media info.
Daskew78
Post by Daskew78 » Sun Aug 25, 2019 12:06 am
Okay I'll give this another go...
It's backing up 800 now and I can see in CopyBD where it says 800, but what I don't see/get is where in CopyBD it says 800 is the one with the Dolby Vision data?
If this backup works and I can figure that out i've cracked it!
Regards
Dave
Post by SamuriHL » Sun Aug 25, 2019 12:42 am
Remember you're not going to be able to PLAY these MKV backups with Dolby Vision. As for your question, CloneBD shows the metadata for each track when you hover over it. Dolby Vision is listed.
Daskew78
Post by Daskew78 » Sun Aug 25, 2019 12:44 am
Yeah I forgot it couldn't be played and it's just for the future...
However, I've just finished backing up 800 and it's not there :(
Regards
Dave
Post by SamuriHL » Sun Aug 25, 2019 12:49 am
Daskew78 wrote: Sun Aug 25, 2019 12:44 am Yeah I forgot it couldn't be played and it's just for the future...
Show me the media info for it. And you DID back it up using MakeMKV and NOT CloneBD.....RIGHT?
