Problematic HD-DVDs
setarip_old
Problematic HD-DVDs
Post by setarip_old »
Although it's come a long way since "Day One" of MakeMKV, it's apparent that HD-DVD backup capability is not yet 100%.
Therefore, if you come across an HD-DVD that you can't successfully back up, please post the following information to this thread only:
1) Title of HD-DVD
2) Studio
3) Video format and codec
4) Audio format(s)
5) Nature of problem when trying to backup
6) Debug log
Please make a separate post for each problematic HD-DVD.
Arakis5
Re: Problematic HD-DVDs
Post by Arakis5 »
Stardust
Paramount
Mpeg4
DDplus
Failed to save title 1 to file
DEBUG: Code 7 at ML7guqhKk;owG;\JTr>*:121264050
DEBUG: Code 0 at o$RAsAp!bG*A&KNptG\;':29397449
DEBUG: Code 0 at g*_tFMoQkzW[<oWsU\$:121263751
DEBUG: Code 0 at kO55^bs+-=`<^:&z>(W:213133204
FYI: Serenity(Universal)/VC1-DDplus worked.
cozzmo
Post by cozzmo »
1) Rebellion (AKA Equilibrium, this was released in japan only on HD-DVD as far as i know)
2) Miramax
3) mpeg4-avc
4) DDPlus (english + japanese)
5) Gets to ~800mb then fails (tried 3 times with 3 different failure points all near the 800mb mark). Used a GGW-H20L + XBOX HD-DVD addon drive. both failed. Visal inspection of disc OK. Plays OK on XE-1 player.
6) Debug log
Saving 1 titles into directory D://REBELLION
DEBUG: Code 2147483647 at 8a;4xqx++vbtp=E-85I:213129984
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file D://REBELLION/t00_PEVOB_01MAIN_1.mkv
0 titles saved, 1 failed
Version 1.6.3 debug - issue remains 01/2011
MakeMKV v1.6.3 win(x64-release) started
DEBUG: Code 0 at HnRz|%TgM^sfC$PfJr{:29393447
DEBUG: Code 0 at RxufbOa<soe!LpBf]:121262164
Saving 1 titles into directory E://REBELLION
DEBUG: Code 2147483647 at <D(>7~k/ojF2_$1l*"w:213129984
Failed to save title 0 to file E://REBELLION/t00_PEVOB_01MAIN_1.mkv
cozzmo
Post by cozzmo »
1) Matrix Reloaded
2) Warner Brothers
3) VC-1
4) DDplus 3/2+1 & TrueHD 5.1
5) When the disc is loaded into the drive, i open MakeMKV, press the Open Disc button then while trying to open the disc, the blow errors appear in the debug window and the disc fails to open.
FIXED / successfully ripped with 1.6.3
MakeMKV v1.6.0 win(x64-release) started
Evaluation version, 29 day(s) out of 30 remaining
DEBUG: Code 0 at L-Mzv($j15?CI&O-y:121262164
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..056AAF62D9F13591C2D5B94902F56173729 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at ~q#Mu\Z-6gLooXxPn:213130743
DEBUG: Code 0 at rMPFQ9_ZpC\*Ugs9bT:29394643
DEBUG: Code 0 at rMPFQ9_ZpC\*Ugs9bT:121262003
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FB8168044F4EE6B00D72C84B4FB5D1A4CD to device 'SPTI:\Device\CdRom1'
DEBUG: Code 1 at rMPFQ9_ZpC\*Ugs9bT:121262003
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07576AC794BD65D49F6B84C29D43770477E to device 'SPTI:\Device\CdRom1'
DEBUG: Code 2 at rMPFQ9_ZpC\*Ugs9bT:121262003
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F1E025E12F4AD8D11BE3188534163C65E2 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 3 at rMPFQ9_ZpC\*Ugs9bT:121262003
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..04BA9564AB0C3AE0004E089924FC4104B49 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 4 at rMPFQ9_ZpC\*Ugs9bT:121262003
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02A87274893FC4EE743CF8272D7839D90B6 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F77EC711D3DFB6F83FBD9BCB4F516B3F27 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..03979E90B7579BD6DD13C9731BE06CBBF4F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09343BE109570ECBA835A4BF7FCAEA5A092 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08D96A3494DBE9E75DFCEA513E7E1497D6E to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..034776D8F7C971F375447525597686727DF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07AE1136A67EBE3CDD4BBAF1D413BCD89DA to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09183CD16F566F805F8179491DEF574A2CE to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..003CB21143266E7EF3E055730F6FAB28449 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08F08EFFD06C650058B8E0094A7DCED7914 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07514D4872090EE9FD255A377527545EB84 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command AD0..080002400 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at ~q#Mu\Z-6gLooXxPn:213130283
DEBUG: Code 0 at rMPFQ9_ZpC\*Ugs9bT:29395356
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0485D58D6176D0010A7AB3CA9E7AEB157ED to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07E7AFFBA067FA5AA5AC0F96D859E707D74 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A0FE97F511A60A8D0EE70ECE0DE04ED7A4 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F154A60AEF47BBE1EBD46A4EF6A14B9DBD to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00DF721B457FFF3ACC923C1ACD1FD59A47C to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08CC6DC11539BFDAC34E973F75539956750 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..016FFFBAD605B6D622F9ABBF3669965CD03 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E8383A616758E0E79FA885A782E73612AF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..087F160991650EE2BFC8B794A0B03168419 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E9E9859AFB46CD67DA70710C545B50E513 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..01F98B911AE7728DE5F55AE53F782DBDBF9 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0651A56238335F8DA42064DCC90316C809E to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..06C8A00A18BCEC694573473334DAE9663AF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..04FCF4251F90461A2CAB296681A17C68554 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at ehvMHF8Z~[4 .:213130168
mpataky
Post by mpataky »
I've tried 2 HD-DVD's so far, Forbidden Planet and Cat People, both had no problems making the "MKV" but there is no audio ... however the video is fine ... no errors in the debug log ... help!!
cozzmo
Post by cozzmo »
mpataky wrote:I've tried 2 HD-DVD's so far, Forbidden Planet and Cat People, both had no problems making the "MKV" but there is no audio ... however the video is fine ... no errors in the debug log ... help!!
Which audio did you choose? what are you using the play it back? I use VLC and it can decode the HD Audio which some other players might not have filters to decode.
setarip_old
@cozzmo
Hi!
Regarding "Matrix Reloaded", please also provide the following information:
3) Video format
4) Audio format(s)
Thank you ;>}
setarip_old
@mpataky
Regarding "Forbidden Planet" and "Cat People", please provide the following additional information:
2) Studio
3) Video format
4) Audio format(s)
mpataky
Post by mpataky »
Forbidden Planet is MGM, 1080p, dolby digital plus ... Cat People -- Universal, 1080p, Dolby True HD or Dolby Digital Plus
cozzmo
Post by cozzmo »
1) Top Gun
2) Paramount
3) mpeg4
4) TrueHD 5.1, DTS 3/2+1
5) Stops at 8961.8mb each time. Disc has been cleaned & checked.
6) Debug log below:
Debug logging enabled, log will be saved as C:\Users\****/MakeMKV_log.txt
Evaluation version, 28 day(s) out of 30 remaining
DEBUG: Code 989 at A/g'goY"dcOFcea@e@@Go:213132974
Saving 1 titles into directory D://TOPGUN
DEBUG: Code 7 at TF(=\P&/_wGL>m6PIvFM:121264050
DEBUG: Code 0 at A/g'goY"dcOFcea@e@@Go:29397449
DEBUG: Code 0 at 8a;4xqx++vbtp=E-85I:121263751
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:213133204
Failed to save title 0 to file D://TOPGUN/t00_Main_Movie.mkv
cozzmo
Post by cozzmo »
1) Total Recall
2) Universal, released through Studio Canal?
3) VC-1
4) DTS 3/2+1
5) MakeMKV Freezes as soon as it starts to copy from the disc. Even Elapsed time freezes.
6) Debug log - Program freezes. Continues to dump errors into the Debug log, this is a snippet. I terminated the program after a few minutes, whole log was over 5.5MB.
Issue remains with 1.6.3 (checked 01/2011). Bluray version of the same movie rips perfectly
Debug log started at Wed Sep 22 08:29:14 2010 , written by MakeMKV v1.6.0 win(x64-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.6.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\****/MakeMKV_log.txt
005050:0000 Evaluation version, 28 day(s) out of 30 remaining
001003:0020 DEBUG: Code 0 at L-Mzv($j15?CI&O-y:121262164
001003:0020 DEBUG: Code 989 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 0 at 6B/VDTmY-h Vtg3=Czx:213131640
vobs=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
001003:0020 DEBUG: Code 0 at 6B/VDTmY-h Vtg3=Czx:213131019
001003:0020 DEBUG: Code 0 at Qw6tPdIGeB]:P.:1gJR;:29394183
001003:0020 DEBUG: Code 9 at Qw6tPdIGeB]:P.:1gJR;:29393309
001003:0020 DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:121262072
001003:0020 DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213129639
001003:0020 DEBUG: Code 0 at ?Jwd0:yMFhs=J"r)VY*:121264993
001003:0020 DEBUG: Code 0 at agf;=R}AWA<jjty*M>{:121266741
001003:0020 DEBUG: Code 1 at agf;=R}AWA<jjty*M>{:213135159
001003:0020 DEBUG: Code 2 at agf;=R}AWA<jjty*M>{:213135159
001003:0020 DEBUG: Code 0 at agf;=R}AWA<jjty*M>{:121266856
vobs=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
001003:0020 DEBUG: Code 6 at Qw6tPdIGeB]:P.:1gJR;:29393309
001003:0020 DEBUG: Code 0 at agf;=R}AWA<jjty*M>{:213135159
001003:0020 DEBUG: Code 2012 at A/g'goY"dcOFcea@e@@Go:213132974
005014:0000 Saving 1 titles into directory D://TOTAL_RECALL
001003:0020 DEBUG: Code 692 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 728 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 596 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 136 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 760 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 744 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 376 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 360 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 716 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 196 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 572 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 772 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 671 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 77 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 736 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 459 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 301 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 756 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 732 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 227 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 537 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 788 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 690 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 70 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 752 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 720 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 474 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 302 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 254 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 466 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 724 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 110 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 650 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 629 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 115 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 740 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 409 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 327 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 213 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 535 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 29 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 715 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 540 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 204 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 748 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 764 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 300 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 436 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 768 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 72 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 672 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 591 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 129 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 88 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 460 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 163 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 577 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 686 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 46 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 482 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 266 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 242 at A/g'goY"dcOFcea@e@@Go:213132974
001003:0020 DEBUG: Code 498 at A/g'goY"dcOFcea@e@@Go:29395747
001003:0020 DEBUG: Code 46 at A/g'goY"dcOFcea@e@@Go:213132974
Post by SamuriHL »
cozzmo wrote:1) Top Gun
2) Paramount
3) mpeg4
6) Debug log below:
I meant to report this one the day 1.60 was released but I didn't get to it. I wanted to make sure I tried with AnyDVD disabled. Made no difference. I got the same exact error.
Krobar
Post by Krobar »
Any chance an option could be added to make debug file names with the Disc Volume ID? I will add debug logs later, its difficult when ripping with multiple instances to use Debug. 1.6.0 is a massive improvement.
1) Babel
2) Paramount
3) Mpeg4
4) DDPlus 5.1
5) Fails at end (Verification?)
1 )Batman Begins
2) WB
3) VC-1
4) TrueHD 5.1
5) Fails about 2/3 of the way through, culd be the disc it looks like layers might be seperating (Like Laserot on laserdiscs)
Krobar
Post by Krobar »
1 )The Jimi Hendrix Experience - Live At Monterey
2) Universal Music
3) ?
4) TrueHD 5.1
5) Immediately Fails to open
Debug log started at Fri Sep 24 11:21:31 2010 , written by MakeMKV v1.6.0 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as C:\Users\Krobar/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at ehvMHF8Z~[4 .:29393654
cozzmo
Post by cozzmo »
1) Shooter
2) Paramount
3) mpeg4
4) DDPlus
5) Stops at 10210.9mb each time, tried 2 times, checked disc surface, clean as. Movie has been played back many times perfectly.
6) Debug log:
Debug logging enabled, log will be saved as C:\Users\*****/MakeMKV_log.txt
Saving 1 titles into directory E://SHOOTER_EU
Failed to save title 0 to file E://SHOOTER_EU/t00_Main_Movie.mkv
