Hi All,
First...thank you to all of you who post helpful advice on this forum!! You guys rock!!
Because of you, I have been able to rip all of my DVD's and Blu Rays (1,400 total). I built a "Ripper" out of an old PC and installed 4 BR drives. I am now looking at my stack of 35+ UHD discs.
I was going to rip them with my Lg wh16ns60, which is currently at the latest firmware. Before I downgrade it, just a few questions:
1) Will the drive still be able to burn blank discs (with commercial software)?
2) Will I still be able to play UHD disc (watch movies) on my PC, with normal software (not VLC)?
3) If I DO downgrade it...can I upgrade it later (OEM release).
TIA!!
Dwayne
Post downgrade questions
Re: Post downgrade questions
1.yes just dont cross flashdcarter4 wrote: ↑Fri Aug 23, 2019 12:48 amHi All,
TIA!!
Dwayne
2.yes
3.yes
Have we tested whether MK 1.01 still works as an official drive? I mean, it SHOULD, but, has anyone ACTUALLY tested it?
i have tested with de 1.00 ill try 1.01mk soon busy with lots of stuff right now
I know 1.00 works but given that mk is a modification of the firmware I don't know if that one does. I'd try it myself but I never got powerdvd to work for uhd.
i can confirm 1.01MK works for official UHD playback on the WH16NS60
Thanks, Billy. Good to know!
