K@mpfH@mster wrote: Thu Aug 22, 2019 3:02 pm
Hi, yes I did it but there is only an FLAC Profile, but where is the high compression profile?
You clearly didn't read the entire thread carefully.
In brief summary:
- Locate 'appdata.tar' in the program directory.
- Extract a copy of 'flac.mmcp.xml' to the data directory.
- Edit your custom copy of 'flac.mmcp.xml' & make the suggested changes:
-- Change '<name lang="eng">
FLAC</name>' >>> '<name lang="eng">
FLAC-BEST</name>' so that it is distinct in the 'Profile' pull-down.
-- Change '<extraArgs>-compression_level
12</extraArgs>' >>> '<extraArgs>-compression_level
10</extraArgs>'. (optional, suggested in post #13).
-- Change ALL instances of '<output outputSettingsName="
flac-fast"' >>> '<output outputSettingsName="
flac-best"'.
-- Save & restart MakeMKV. The 'Profile' pull-down will include the new entry.
flac.mmcp.zip
These ought to achieve the basic requested 'high compression profile'.
