FLAC Quality selection????
Re: FLAC Quality selection????
Post by d00zah »
K@mpfH@mster wrote: Thu Aug 22, 2019 2:39 pm Hey guys, I have searched everything, but I cant find a solution. I am using the newest version and would like to use FLAC profile, but with highest possible compression. Cant find an option anywhere.
Have you followed the instructions in post #8?
https://www.makemkv.com/forum/viewtopic ... 964#p56535
It exposes a 'Profile' pull-down below the 'Make MKV' button that starts the creation process.
K@mpfH@mster
Post by K@mpfH@mster »
Hi, yes I did it but there is only an FLAC Profile, but where is the high compression profile?
Post by d00zah »
K@mpfH@mster wrote: Thu Aug 22, 2019 3:02 pm Hi, yes I did it but there is only an FLAC Profile, but where is the high compression profile?
You clearly didn't read the entire thread carefully.
In brief summary:
- Locate 'appdata.tar' in the program directory.
- Extract a copy of 'flac.mmcp.xml' to the data directory.
- Edit your custom copy of 'flac.mmcp.xml' & make the suggested changes:
-- Change '<name lang="eng">FLAC</name>' >>> '<name lang="eng">FLAC-BEST</name>' so that it is distinct in the 'Profile' pull-down.
-- Change '<extraArgs>-compression_level 12</extraArgs>' >>> '<extraArgs>-compression_level 10</extraArgs>'. (optional, suggested in post #13).
-- Change ALL instances of '<output outputSettingsName="flac-fast"' >>> '<output outputSettingsName="flac-best"'.
-- Save & restart MakeMKV. The 'Profile' pull-down will include the new entry.
flac.mmcp.zip
(930 Bytes) Downloaded 1181 times
These ought to achieve the basic requested 'high compression profile'.
eonmc2
Post by eonmc2 »
d00zah wrote: Thu Aug 22, 2019 4:18 pm You clearly didn't read the entire thread carefully.
flac.mmcp.zip
Thanks! I was looking for this information because the scene rules state:
    9.7) FLAC must be used for lossless mono and lossless stereo tracks, as well as multi-channel LPCM tracks.
        9.7.1) The best compression (level 8, --compression-level-8) must be used.
source: https://scenerules.org/t.html?id=2020_X265.nfo
I changed level to 8 as required.
A copy of the .mmcp.xml file with --compression-level-8 is inside this .rar:
flac.mmcp.rar
(882 Bytes) Downloaded 276 times
edit.
Added notes from the scene rules to this version:
LPCM_to_FLAC8_SceneRules.mmcp.rar
--compression-level-8 with notes
(1.26 KiB) Downloaded 291 times
