de wh16ns60 1.00Daskew78 wrote: Thu Aug 22, 2019 6:49 am I think it is this one but not sure:
DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50
Drive making funny noises
Re: Drive making funny noises
Great, that seems to have done the trick as it's reporting it as the wh16 v1.0 now, thank you!
So just to clarify:
1) I should have no more issues with the sleep bug?
2) Will the drive operate any faster or have any other benefits now it's using the WH16 firmware as apposed to the WH14 I was using?
3) Lastly, What is the difference between the NS50 1.02 and NS60 1.0 I have just flashed?
Thanks for your help.
So just to clarify:
Regards
Dave
Dave
1. yesDaskew78 wrote: Thu Aug 22, 2019 7:04 am Great, that seems to have done the trick as it's reporting it as the wh16 v1.0 now, thank you!
So just to clarify:
2. yes it save about 7 mins on a 60gb disk
3. the sleepbug fix, it being faster and uhd disks only work in programs that support uhd official drives not uhd friendly
All sounds fantastic!!!
Not sure about what you mean here though:
“uhd disks only work in programs that support uhd official drives not uhd friendly”
So will I be able to play UHD disks on the PC now as well where I couldn’t before?
Regards
Dave
Dave
niketsurve
Thanks for the explaination.
