Alita: Battle Angel 4K Correct Playlist?
Thornback
Re: Alita: Battle Angel 4K Correct Playlist?
Post by Thornback » Mon Aug 19, 2019 10:00 am
lwndow wrote: Sun Aug 18, 2019 5:23 pm
buggystick wrote: Sat Aug 10, 2019 4:26 am So I recently bought Alita: Battle Angel from Amazon and for some reason the disc is not UHD. It has both the bluray and the 3D disk, but makemkv isn't showing a 4K playlist, just 1080p. This disk is brand new, just took the shrink wrap off and it says "4K UltraHD" at the top...
Did I somehow get a non UHD disk in a UHD box?
How did you get the light descriptions to show up in parens next to the titles? Very cool.
I would like to know this too please.
sharpie00
Post by sharpie00 » Wed Aug 21, 2019 12:11 am
on a mac, install homebrew (if you don't already have it installed...search for homebrew on google).
then run this command in your terminal window:
brew cask install adoptopenjdk/openjdk/adoptopenjdk8
once completed, open up MakeMKV and go to Preferences > Protection > Custom Java executable location and enter this path:
/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Restart MakeMKV and you should be good to go.
blurayfan2019
Post by blurayfan2019 » Wed Aug 21, 2019 3:49 pm
You may already have the version you need without installing another version. Look at /Users/user/MakeMKV_log.txt. You should see something like this:
Found java version=12.0.2 path=/Library/Java/JavaVirtualMachines/jdk-12.0.2.jdk/Contents/Home/bin/java
Found java version=1.8.0.221 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
For some reason, the app chooses the first version, which causes the error. Copy and paste the path of the second version (/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java), which is the correct version, into MakeMKV preferences->Protection->Custom Java executable location. This worked for me.
lwndow
Post by lwndow » Sat Aug 31, 2019 5:44 pm
Thanks so much for posting this. For those that were curious like me, since there are multiple versions of the JDK:
It does need to be JDK version 8, versions 11 & 12 will not work the same way. After cask installing, mine installed to
/Library/Java/JavaVirtualMachines/adoptopenjdk-8.jdk
not to:
No need to make the symlink, placing
/Library/Java/JavaVirtualMachines/adoptopenjdk-8.jdk/Contents/Home/bin/java
in the MakeMKV config works just as well.
Thanks again, what a time saver!
blurayfan2019
Post by blurayfan2019 » Sat Aug 31, 2019 6:08 pm
Well, as I already pointed out
works just fine without installing jdk 8.
ksalno
Post by ksalno » Sun Oct 13, 2019 6:16 pm
Trying to rip my first 4K UHD disc and using Alita to learn. I've ripped using Makemkv to a USB drive and attached that to an Oppo 205 for playback. I get video but no audio. I tried to minimize the size of the file, so I only ripped the Main Feature with 7.1 and 5.1 audio. No subtitles and no foreign languages. Am I missing something critical for audio?
blurayfan2019
Post by blurayfan2019 » Sun Oct 13, 2019 6:26 pm
That's really odd. You didn't select the Title yet you got video. Try selecting the title and the audio.
ksalno
Post by ksalno » Mon Oct 14, 2019 2:09 am
blurayfan2019 wrote: Sun Oct 13, 2019 6:26 pm That's really odd. You didn't select the Title yet you got video. Try selecting the title and the audio.
I didn't have the title checked when I took the screenshot but I did when I actually ran the MakeMKV. I figured out the problem. I had the Oppo 205 Audio HDMI out set to force Bitstream instead of Auto. Funny enough an Atmos demo file I have on USB stick works fine but that was an MP4 file format. Once I switched the Oppo to Auto, the 205 started sending an LPCM stream to my processor and it decoded it as Atmos 7.1.
blurayfan2019
Post by blurayfan2019 » Mon Oct 14, 2019 2:13 pm
Oh, good that that was all it was.
granular.mandate
Post by granular.mandate » Tue Dec 22, 2020 11:49 am
English:
Source file name: 00800.mpls
Segment map: 687,688,674,689
Source file name: 00801.mpls
Spanish:
Source file name: 00802.mpls
Segment map: 692,688,18,689
Source file name: 00804.mpls
Segment map: 691,688,15,689
French:
Source file name: 00803.mpls
Segment map: 6,688,21,689
German:
Source file name: 00805.mpls
Segment map: 4,688,674,689
Italian:
Source file name: 00806.mpls
Segment map: 690,688,17,689
Russian:
Source file name: 00807.mpls
Segment map: 694,688,19,689
Polish:
Source file name: 00808.mpls
Segment map: 693,688,674,689
