Error with JRE on bluRay Eighth grade
rmsudo
Post by rmsudo »
The following is my log. Not sure if anyone has any thoughts, but essentially the detect main title thing did not work again and I am not sure if this is the issue. (Running on Mac X.14.2)
MakeMKV v1.14.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/dussaqMacMini/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-XD05 3.10d" opened in OS access mode.
Optical drive "BD-ROM hp DVDWBD TS-LB23L 0400d" opened in OS access mode.
Using Java runtime from /Library/Java/JavaVirtualMachines/openjdk-11.0.2.jdk/Contents/Home/bin/java
DEBUG: Code 0 at s<}w+kP?q)[m!'b:k9j{:213133204
Grauhaar
Re: Error with JRE on bluRay Eighth grade
Post by Grauhaar »
Provide the debug log: "Debug logging enabled, log will be saved as /Users/dussaqMacMini/MakeMKV_log.txt"
Good Luck :)
rmsudo
Post by rmsudo »
Same error with "First Reformed" Allowed me to grab the actual log file... Sorry for the delay.
Debug log started at Thu Feb 21 00:13:30 2019 , written by MakeMKV v1.14.2 darwin(x64-release)
001005:0000 MakeMKV v1.14.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/dussaqMacMini/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE PIONEER BD-RW   BDR-XD05 3.10d" opened in OS access mode.
002010:0000 Optical drive "BD-ROM hp DVDWBD TS-LB23L 0400d" opened in OS access mode.
DEBUG: Code 2365587456 at (/YVlr[>h*N'AVA5k:29394620
DEBUG: Code 0 at -IbFTgc^Y5R&Ax,0:213140587
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:29401014
DEBUG: Code 2147483648 at -IbFTgc^Y5R&Ax,0:121265223
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
DCE=JUIJhT05JV8rHsFQsIM9EF9mZcbV27PisqQgYE2Kqk1nS3zTmZ8E5WuZtMsD3NpxHczoDAMG2QwgDGIYO7Pawbo951c20w/8JMFDvVigbwhwEFblrsJYoPKDQPH9Mwpa68XFeIZ5kj7Si8M2P4SOKZO0LWtDIm5Jmw==
DCE=QhF4jR2m6hgu3s8cGX9IOcYjydTC58VtW30iB/uYy+nk/et1uvP8HkTGd6jhPI0fEbGZqTwvtN0sduaI/AAXMZDHhaVOKUsoZUdiEn3RcLdm1SPEypualul5NQ+ouMRvRqw0dVpraTi20ak2p4P0Pdr8Oyh4EFuCQw==
Found java version=11.0.2 path=/Library/Java/JavaVirtualMachines/openjdk-11.0.2.jdk/Contents/Home/bin/java
Found java version=1.8.0.201 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
003344:0000 Using Java runtime from /Library/Java/JavaVirtualMachines/openjdk-11.0.2.jdk/Contents/Home/bin/java
java_exception(6) : java.lang.NullPointerException
	at com.makemkv.Runtime.a(Unknown Source)
	at com.makemkv.Runtime.b(Unknown Source)
	at com.makemkv.g.action(Unknown Source)
	at blues.Server.actionInvoke(Server.java:245)
	at blues.Server.access$000(Server.java:33)
	at blues.Server$1.run(Server.java:196)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at java.base/java.lang.Thread.run(Thread.java:834)
001003:0020 DEBUG: Code 0 at s<}w+kP?q)[m!'b:k9j{:213133204
DISCID=ED62F66E2669F241E0184722D4512C3386ED06A9
003025:0000 Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
rmsudo
Post by rmsudo »
For anyone who happens upon this: Java-11 is not supported, install java8 instead and things work well.
If you are a mac/brew user:
brew cask uninstall java
brew cask install java8
Should do the trick.
blurayfan2019
Post by blurayfan2019 »
I had the same problem:
Found java version=12.0.2 path=/Library/Java/JavaVirtualMachines/jdk-12.0.2.jdk/Contents/Home/bin/java
Found java version=1.8.0.221 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
003344:0000 Using Java runtime from /Library/Java/JavaVirtualMachines/jdk-12.0.2.jdk/Contents/Home/bin/java
I didn't know there was any Java version limitation or requirement. Thanks for pointing this out. I don't think there was any need to uninstall the latest version and install an older version. I simply changed the blank line in MakeMKV preferences->Protection->Custom Java executable location to /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java, the location of version 1.8.0.221, and that worked. Now I get no errors and I see extra title information that was missing before. I also installed the JDK 8 Update 221, which is actually java version "1.8.0_221", and that worked too. I entered /Library/Java/JavaVirtualMachines/jdk1.8.0_221.jdk/Contents/Home/bin/java in the above-mentioned field and got the same results.
sharpie00
Post by sharpie00 »
since Java 8 is no longer available in homebrew, use the following command to install the jdk instead.
brew cask install adoptopenjdk/openjdk/adoptopenjdk8
then follow blurayfan2019's recommendation. works great.
blurayfan2019
That's an interesting way to install it. Or you can get the pkg installer from Java Downloads for All Operating Systems. That's what I did. I install all updates from the command line since they often hang otherwise.
installer -verboseR -dumplog -pkg "path/to/JDK 8 Update 221.pkg" -target / -store
This prints out the path to the JDK, which was
/Library/Java/JavaVirtualMachines/jdk1.8.0_221.jdk/Contents/Home/jre/bin/java
You can avoid all this by looking at the MakeMKV log and copying and pasting the path of the JavaAppletPlugin, which in my case was
