Error on DVD "Gwendoline"
colemar
Post by colemar » Sun Sep 19, 2010 3:50 pm
$ makemkvcon --debug mkv file:VIDEO_TS 0 .
MakeMKV v1.6.0 linux(x86-release) started
Debug logging enabled, log will be saved as /home/admin/MakeMKV_log.txt
DEBUG: Code 0 at DyYz+&phrXsv1&uswl]]lhm:121262325
DEBUG: Code 0 at l\;8Gs6E# 9wtaj:213130214
The program can't find any usable optical drives.
Opening files on harddrive at VIDEO_TS
DEBUG: Code 0 at &Y?Bm`PRh{iUwi:121267776
DEBUG: Code 0 at a-vsR{q=Pu@|Ii(P:121265798
DEBUG: Code 0 at a-vsR{q=Pu@|Ii(P:121263314
DEBUG: Code 0 at a-vsR{q=Pu@|Ii(P:29396943
DEBUG: Code 2147483647 at "=fb2qz~-r{PO7~n9`:29395839
DEBUG: Code 2147483647 at "=fb2qz~-r{PO7~n9`:121261727
Error 'Posix error - Unknown error 1073741823' occurred while reading 'VIDEO_TS/VIDEO_TS.IFO' at offset '49152'
Error 'Posix error - Unknown error 1073741823' occurred while reading 'VIDEO_TS/VIDEO_TS.BUP' at offset '49152'
DEBUG: Code 0 at `+I*gG2#(e82XJ:121266120
DEBUG: Code 24 at vCkr!k@&Ms"-N\:213129823
Calculated BUP offset does not match one in IFO header.
Error 'Posix error - Unknown error 1073741823' occurred while reading 'VIDEO_TS/VTS_01_0.IFO' at offset '88064'
Error 'Posix error - Unknown error 1073741823' occurred while reading 'VIDEO_TS/VTS_01_0.BUP' at offset '88064'
DEBUG: Code 0 at Xck`9_d:RNfxiJJ9Z:121262785
Attached files VIDEO_TS.IFO, VTS_01_0.IFO:
Gwendoline.rar
setarip_old
Re: Error on DVD "Gwendoline"
Post by setarip_old » Mon Sep 20, 2010 2:38 am
Hi!
It appears that you have a problematic rip on your hard drive.
1) Have you tried cleaning and re-ripping the original, commercial DVD? (Remove peanut butter and jelly, etc. from this soft core title ;>})
2) Is it a NEW DVD?
3) Is the original, commercial DVD physically damaged (scratches, etc.)?
colemar
Post by colemar » Mon Sep 20, 2010 8:35 pm
It's not a rip of mines, so I don't have the original disc.
It seems the rip was made on 2009-04-21.
If the rip were not good, I would expect some differences between *.IFO and *.BUP files; instead, they do not differ.
The following command works without apparent problems, and the resulting file seems good and complete:
tccat -t dvd -i . > gwendoline.mpg
(tccat is a tool from transcode package)
setarip_old
Post by setarip_old » Tue Sep 21, 2010 5:29 am
Discussion of downloaded or any other type of "other-than-purchased" commercial DVDs or Blu-ray discs is inappropriate at the MakeMKV forums...
Post by mike admin » Tue Sep 21, 2010 7:55 am
It's a bad rip. You should get an original disc.
