Trying to rip Farscape The Peacekeeper Wars and it errors just a second or so after it starts. Here is the error log:
MakeMKV v1.6.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Ronald Scott Moody/MakeMKV_log.txt
Title #0 was added (27 cell(s), 3:03:07)
Title #1 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/FARSCAPE_PEACEKEEPER_WARS
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213130490
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213129639
DEBUG: Code 0 at }{8{aR.=caXQCH>Dnff:29394183
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29394160
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29395195
Failed to save title 0 to file C:/Video/FARSCAPE_PEACEKEEPER_WARS/title00.mkv
0 titles saved, 1 failed
Farscape PKW will not rip
Re: Farscape PKW will not rip
It appears to rip when the audio is de-selected. I tried ripping to MKV with DVDFab and the audio was severely out of sync, the video was way ahead of the audio.
I will try to mux the audio ripped with DVDFab to the audio from MakeMKV and see what that does and report back.
Using the video from MakeMKV and the audio from DVDFab I managed to get a useable MKV after muxing the streams together. Still odd.
- Contact:
What audio track causes this? Primary audio, DD or DTS?
There was only one audio track listed, it was DD 3/2+. I will attach a screen shot for you.
setarip_old
I don't know if this has any bearing on the problem but, the Debug log indicates "Title #0 was added (27 cell(s), 3:03:07)", while the screencapture indicates the title being comprised of 25 chapters.
Additionally, online research about this first disc of a two-disc release indicates a running time of 3:02:00, not 3:03:07...
- Contact:
Looks like a new protection. Please send IFOs per instructions at http://www.makemkv.com/faq/item/8/catid/6 .
*.IFO's and error log have been sent in and attached here just in case. Thanks so much!
