Predator Ultimate Edition BD+
stickleback
Having a problem with Region 2 version of Predator Ultimate Edition. Im using the latest allcombo.svq but getting failed to process disc.
Karl
Karl
setarip_old
Re: Predator Ultimate Edition BD+
Hi!
Download and try the just-released v.1.6 of MakeMKV...
stickleback
Tried the latest version but still no joy.
Karl
Karl
setarip_old
Sounds like you have a dirty or damaged disc...
What AACS number did MakeMKV display?
stickleback
The disc is brand new. BD+ AACS v17, BD+. Its failing on the BD+ decryption (using latest allcombo.svq), details below:
MakeMKV v1.6.0 darwin(x86-release) started
Optical drive "BD-ROM TSSTcorp DVD-ROM SH-D162C TS04" opened in OS access mode.
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ05" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH08LS20 2.00" opened in OS access mode.
Loaded 37 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/karl/Movies/SVQ/dump_PREDATOR_D7B67FE7B4FBEFA5.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Hi!
Did you submit the SVQ dump file?
- Contact:
Added to SVQ, should work now. BD+ status updated at http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612
AchiveAndy
Any update on this? I can open the disc, can back it up as well, but the video stutters when I try to seek manually forward or backward. I don't know what the problem is.
You are asking about a dozen-year-old post.
Most likely, your video playback device cannot handle the amount of data present.
