Forced update to 1.6 now not working
mwk1000
I recently downloaded 1.5.8 for Ubuntu 10.04 and was thrilled that I had no issues with my first 2 blueray disks ripped and decoded to disk
I wanted to try some more this morning and I could not start 1.5.8 I had to download 1.6, After doing so all I get are errors( See below ) on 3 more disks.
Just for sanity I went back to the disks that worked fine on 1.5.8, they no longer work.
I attempted as root or the user "media" no difference.
Very dejected I was looking forward to blueray's on the hometheater PC. FYI , Forcing upgrades from working versions is NOT something I am a fan of. No way to tell if it is 1.6 or something that may have changed on the system. I tried to reinstall 1.5.8 and shut down the internet but no-joy you must write it somewhere on my system. Please notify of updates but don't require them.
Losts of :
Debug log started at Sun Sep 19 15:06:29 2010 , written by MakeMKV v1.6.0 linux(x64-release)
001005:0000 MakeMKV v1.6.0 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
001003:0020 DEBUG: Code 5 at 9[rBBgI6(T9<'e}hV-3}:29394965
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred whil
e issuing SCSI command A30..00200540200520..01CD1230C72150742A96BDC0DCAE8025B1F to device 'SG:dev_11:1'
001003:0020 DEBUG: Code 0 at :/$#$MElk<_6zwu5Q:213130743
001003:0020 DEBUG: Code 0 at zSo4r-6 ]>j-&yvZt4:29395103
001003:0020 DEBUG: Code 0 at zSo4r-6 ]>j-&yvZt4:121262003
e issuing SCSI command A30..00200540200520..049A1158A1A0D23208F07EF1F53561EC702 to device 'SG:dev_11:1'
001003:0020 DEBUG: Code 1 at zSo4r-6 ]>j-&yvZt4:121262003
Losts of :
grondinm
Re: Forced update to 1.6 now not working
i am also getting the same thing every blu-ray i insert gets this error...even ones that worked before... here is my debug log
this was for Lord of the rings The return of the king(wich worked with 1.5.8 )
this is for Lord of the rings The fellow ship of the ring:
make mkv crashes with Fatal error occurred. Program will now exit
this happens every time on the same file /AACS/MKB_RO.txt. Just confirmed that The fellow ship of the ring also works with 1.5.8
log of successful save of Fellow ship of the ring with 1.5.8:
Debug log started at Sun Sep 19 16:46:44 2010 , written by MakeMKV v1.6.0 linux(x64-release)
001004:0000 Debug logging enabled, log will be saved as /home/marc/MakeMKV_log.txt
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 0 at :/$#$MElk<_6zwu5Q:213130283
001003:0020 DEBUG: Code 0 at zSo4r-6 ]>j-&yvZt4:29395356
001003:0020 DEBUG: Code 2 at zSo4r-6 ]>j-&yvZt4:121262003
001003:0020 DEBUG: Code 3 at zSo4r-6 ]>j-&yvZt4:121262003
001003:0020 DEBUG: Code 0 at NJ%w1'ODCv.03O5F:121261635
001003:0020 DEBUG: Code 0 at NJ%w1'ODCv.03O5F:121261635Code: Select all
Debug log started at Sun Sep 19 16:53:27 2010 , written by MakeMKV v1.6.0 linux(x64-release)
001003:0020 DEBUG: Code 0 at NJ%w1'ODCv.03O5F:121261635this happens every time on the same file /AACS/MKB_RO.txt. Just confirmed that The fellow ship of the ring also works with 1.5.8
Debug log started at Sun Sep 19 17:01:24 2010 , written by MakeMKV v1.5.8 linux(x64-release)
001005:0000 MakeMKV v1.5.8 linux(x64-release) started
005075:0000 The new version 1.6.0 is available for download at http://www.makemkv.com/download
DISCID=21A9E7A66311108362AA8E2B1F3EF5402DA0814A
003307:0000 File 00100.mpls was added as title #0
003025:0000 Title #00120.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00022.m2ts was added as title #1
003307:0000 File 00021.m2ts was added as title #2
003307:0000 File 00009.m2ts was added as title #3
003025:0000 Title #00017.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory /media/Storage/BluRay/RipTemp/THE_LORD_OF_THE_RINGS_THE_FELLOWSHIP_OF_THE_RING
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.-
pynux
i have the same probleme since i have upgrade makemkv
i have the last firmware for my drive
anothergene
make that three. I have it with Battlestar Galactica Complete Series.
Debug log started at Sun Sep 19 21:53:36 2010 , written by MakeMKV v1.6.0 linux(x64-release)
001004:0000 Debug logging enabled, log will be saved as /home/gmoreau/MakeMKV_log.txt
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..02978B621BB2D8809FEC09AE40DF90F5D34 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..02CFC4DD138E9D15E4DCF5F33BCFB51F108 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..00CDA0CEFBDA0D5CA5810269F105EC6D64B to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..093779618804344E349A02C9E903438B8AE to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..04A6D92A5E27CD80D316CE44D42A058C985 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 4 at zSo4r-6 ]>j-&yvZt4:121262003
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..055D1FCE2D8BAB388F1B2066F84A99BA819 to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0333212A01CFA007C46DC29BCE31F3CEB10 to device 'SG:dev_11:0'
replica9000
1.5.8 was running ok for me, but now I get this, even with disc that worked before:
This is with Star Trek VIII: First Contact
Also, the front page says this:
"Program is time-limited -- it will stop functioning after 60 days. You can always download the latest version from makemkv.com that will reset the expiration date."
I only have 30 days, and it didn't reset!
Isn't there a way to keep the older version running until a new version works??
makemkvcon info disc:0
Evaluation version, 9 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..067F428F59372EA58C3ECD0A90879D5516E to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..08EFEE70CD62101996854E296392999C339 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0930825A588122D6E4CA0694501F9CE4FAE to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..06342A06CAD027609F699D61CE9FFDFC5C3 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..00C106A6F0371B2A657C1DD8CCEA0BB31DC to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0815D88829F30208F85C3D7826ABAA3370C to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0033165096DA1176870EDA45468F2E8F68A to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..05CFEC4F200FAAF9F6ECF7F15C63EDB1C1B to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..09638860645A5F03EE18D6A21A1F80F8C92 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..014854315264E6AC6FB80CC426F33393CEF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03D4145A1D949503CD5B067ECA275514867 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0948CDC1FD41DA39ABFDEF1368A712BBBD7 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0713A1669D782DD8E3D8CE7F958D4E60A87 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D1940D4549D745A19B43FF11DC09F1CFC2 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..012AD556FB37D956B49A4B31EEF28665CFE to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..029E386F13D8F72D0DE2998FE32A2AE8B04 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0711F477B95A4528FEC17DD8BAD786B97D4 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0565F9B7613C57D5316086ACE0C02A0A5F9 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..0517002F0A38F1E54C0DE1D19EC5E5964D4 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..02735F19263DBAD775AC88654FBFDD1CAA9 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..090F16C5311D83895973CEFD95591A1D73E to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..085D55834B7F72087AE5ABAC732A0213988 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..077F408DC8A9E74FE2B7F70D18E081DA531 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..054660F5107514D7FA28377901EDFE62B05 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200540200520..004B3166D5EBF8A83EA743065C41077A157 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..010157B5A0CC5D9B44F069987FC12B25C4C to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06713A10E4AF87B4A5273BCC51E9409AA6E to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..034C9AB533675E9005775F6A84847384317 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BED248C755BFC843482A7EAF66B7AFA420 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0245A38B7C3DD99F5DC6FFF90FD89E89EDB to device 'SG:dev_11:0'
Total 0 titles"Program is time-limited -- it will stop functioning after 60 days. You can always download the latest version from makemkv.com that will reset the expiration date."
Ouch. Can someone please try a 32-bit version and see if it works?
MakeMKV has no forced update. You should be able to use 1.5.8, providing you set the clock to september 2nd 2010, enter the current beta key and revert clock to real date.
grondinm
i will boot up a live cd 32-bit Ubuntu and see what happens...will update later today.
grondinm
so 1.6.0 under Ubuntu 10.04 32-bit running in VirtualBox works fine. here is a log for proof...i figure if it works in VB it would work normally...if you want i can boot live cd and try it that way as well. let me know and keep up the good work.
also on a second note i am noticing that the time in the log is not the system time...not that it's that big a deal....
Debug log started at Mon Sep 20 20:22:02 2010 , written by MakeMKV v1.6.0 linux(x86-release)
Using 127104KB for read cache.
001005:0000 MakeMKV v1.6.0 linux(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /home/ubuntu32bit/MakeMKV_log.txt
DISCID=9E3BED1C50A1F4D4F1A6D62BD5BA084A49708615
003025:0000 Title #00120.mpls has length of 90 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 84 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003307:0000 File 00007.m2ts was added as title #1
003025:0000 Title #00017.m2ts has length of 34 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 180 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 6 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 63 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 56 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 25 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 17 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 47 seconds which is less than minimum title length of 300 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /home/ubuntu32bit/Videos/THE_LORD_OF_THE_RINGS_THE_RETURN_OF_THE_KING
kdemello
Not working here either, though backup still seems to work.
Pity, I was about to buy the software, but if I can't even verify that 1.5.8 still works anymore, there's no point.
grondinm
kdemello are you on 64 or 32 bit?
Jagaer
Same "Scsi error - ILLEGAL REQUEST"
Gentoo 64 bit
For those that want MakeMkv 1.5.8:
bin - http://www.makemkv.com/download/makemkv ... bin.tar.gz
oss - http://www.makemkv.com/download/makemkv ... oss.tar.gz
Edit your ~/settings.conf and add the line:
app_Key = "T-kQ8lHCLcluYdZUHqy5T85oGo3vMXm31MyqAFlAKul2pGyIGY4PmRHWpRxUyhf4xbkS"
Gentoo 64 bit
weiln
I've used MakeMKV consistently across Windows (32/64 bit), and Ubuntu x64 with no problems, until 1.6. Now I get the same error as above with ILLEGAL REQUEST, however it also crashes about 50% of the time. I've included two error logs, one from running as "root", and one from running as my normal account. Root actually crashed and almost always does. My normal account didn't this time, it just refused to open the disc.
All the errors are running 1.6 on Ubuntu 10.04 x64, kernel 2.6.32-25-generic.
I hope this helps the team get a fix released, because I love the software.
Nathan
Nathan
It's confirmed - 1.6.0 x64 is broken and there is no workaround. The 1.6.1 update is now available, only binary part is updated, oss is still 1.6.0 and doesn't need to be updated.
grondinm
just wanted to confirm that 1.6.1 has fixed the issue for me. thanx mike for the quick update keep up to good work.
anothergene
Thanks for the quick turn around and keep up the great work!
