Avengers 4 endgame
Re: Avengers 4 endgame
I just sent my dump from the US Cinematic Universe Edition
So far, mine will not decrypt.
UHD official or friendly drive? "Volume key is unknown for this disc" for me with BW-16D1HT drive. EDIT: I see that you used the same drive, just as backup instead.
handcraftedbits
Remember that they don't just manufacture these discs with a single volume key, many of them are in play. That's what it'll work for some people and not others -- it's just luck of the draw if you managed to get a disc with the same key as someone else who submitted their dump before you.
Noted - thanks.handcraftedbits wrote: ↑Wed Aug 14, 2019 12:51 amRemember that they don't just manufacture these discs with a single volume key, many of them are in play. That's what it'll work for some people and not others -- it's just luck of the draw if you managed to get a disc with the same key as someone else who submitted their dump before you.
Yup, and as noted, even the same store/type of disc (i.e. best buy steel book) can have different title keys, as well. It's not by country, either. It's just random.
handcraftedbits
Another FYI for anyone new to this, you'll always be able to do a full disc backup, even if the keys aren't known yet (no actual decryption takes place). This is precisely what I do when I get a "volume key unknown" error. Back it up, put away the disc forever, and check back in a few days.
I did this a bit earlier - thanks for the confirmation.handcraftedbits wrote: ↑Wed Aug 14, 2019 1:45 amAnother FYI for anyone new to this, you'll always be able to do a full disc backup, even if the keys aren't known yet (no actual decryption takes place). This is precisely what I do when I get a "volume key unknown" error. Back it up, put away the disc forever, and check back in a few days.
Yea, I have a script that I use that enables LibreDrive mode for the drive and then uses ImgBurn to create a protected ISO. Same idea. Just open the ISO with MakeMKV to check if it's supported periodically.
Good stuff - this is the first time in my admittedly limited exposure to extracting from physical media that the key didn't exist to address directly from disc. Creating a backup does seem like the logical path rather than relying on the disc again down the road.
Yup makes it much easier for when the key is released.
Thanks all. I did not know how it worked thus asking. Learned something new.
For what it is worth the backup/makemkv file played perfectly fine. Ubuntu server, plex, and nvidia shield to older 4k LG set. Again, thank you for the information as when the next disc fails and creates a dump I won't ignore it and wait like I usually did.
Just submitted a dump for my Best Buy Steelbook Avengers: Endgame disc. I'm looking forward to making a slightly edited version of this via Adobe Premiere Pro for my own enjoyment (making edits of my favorite movies and shows is a hobby of mine).
Iron Man 1-3 ripped fine
Thor 2 ripped fine
Thor 1 and Endgame, still no dice. submitted dumps.
all discs from Best Buy steelbooks
Thor 2 ripped fine
I have been ripping discs since before mkv worked with UHD and never thought about doing that! Makes perfect sense, and thanks for the tip..handcraftedbits wrote: ↑Wed Aug 14, 2019 1:45 amAnother FYI for anyone new to this, you'll always be able to do a full disc backup, even if the keys aren't known yet (no actual decryption takes place). This is precisely what I do when I get a "volume key unknown" error. Back it up, put away the disc forever, and check back in a few days.
handcraftedbits
My regular copy purchased from Best Buy just decrypted. That's gotta be the quickest turnaround I've seen. Poor Mike was probably getting swamped with emails for this one.
