Hellboy (2019) - Which Playlist?
kevonator
Re: Hellboy (2019) - Which Playlist?
#31 Post by kevonator » Mon Aug 12, 2019 6:07 pm
Anybody know correct playlist for Netflix?
KiltedShane
#32 Post by KiltedShane » Tue Aug 13, 2019 10:17 pm
kevonator wrote: Mon Aug 12, 2019 6:07 pm Anybody know correct playlist for Netflix?
Name: Hellboy (English)
Source file name: 00377.mpls
Duration: 2:01:02
Chapters count: 16
Segment count: 10
Segment map: 507,506,504,501,502,508,511,509,503,505
This is according to Process Monitor using the process laid out here https://www.makemkv.com/forum/viewtopic.php?t=16251
jeep_dawg
#33 Post by jeep_dawg » Wed Aug 14, 2019 10:35 pm
so when is this piece of shit going to start working with playlists?!
darcym
#34 Post by darcym » Mon Sep 09, 2019 6:07 pm
thanks to the moderator for linking my thread to this one - I clearly didn't find it with the correct search function.
I'm ripping the UK retail version - it has 500+ titles in, but doesn't have any of the approved mpls files 377 or 510
How do I work out which one I need to actually rip ?
darcym
#35 Post by darcym » Tue Sep 10, 2019 6:07 am
by playing the film and going through the bluray's menus for play info, the best I could get was the title being played was 01 202, which I'm hoping represents the file 202 (chapter one of file 202) but I don't know yet.
darcym
#36 Post by darcym » Tue Sep 10, 2019 8:40 am
I was wrong, 202 does not mean the filename 202 - 202 is really out of sequence.
sandersoni
#37 Post by sandersoni » Thu Sep 12, 2019 11:07 pm
UK Retail
Title information
Source file name: 00527.mpls
Duration: 2:01:02
Chapters count: 16
Segment count: 17
Segment map: 511,504,508,517,501,510,505,502,512,516,507,506,515,514,500,513,509
File name: HELLBOY_t219.mkv
via Process Monitor
darcym
#38 Post by darcym » Fri Sep 13, 2019 12:21 pm
I'll give it a try, thank you.
I'm curious to how you came to that track being the right one ?
darcym
#39 Post by darcym » Sat Sep 14, 2019 9:31 am
looks good - thank you, I'll try an encode now and sit back and watch the film properly.
Still can't work out how you came to know that looked like the right file ?
oddeyeball
#40 Post by oddeyeball » Fri Sep 20, 2019 3:03 am
I just tried 00510.mpls for my retail Hellboy (Blu-ray, DVD, digital combo) and it appears to be the correct one. Upon inspecting the segments, segment 505 and 508 appear to be the same clip. Interesting indeed.
jameshump
#41 Post by jameshump » Fri Nov 15, 2019 11:39 am
HI Guys
I am in the UK and could use some help which is the correct playlist for Hellboy (2019) I have tried 527 that is incorrect, I do not have 510 or 377 on mt playlists so I cam completely confused???
Can someone help?
mtbdrew
#42 Post by mtbdrew » Sun Dec 01, 2019 1:18 am
Just picked up a retail Blu-ray from Costco and it doesn't have any of the mentioned above. IE no 377, 378, 510 or 527 nor do any of the chapter listed match what has been suggested so far.
mtbdrew
#43 Post by mtbdrew » Sun Dec 01, 2019 1:23 am
518 is the last listed on my retail disc and it doesn't have 377 or 510 either. So far all that I have tried have sections missing or playing out of order.
troyBORG
#44 Post by troyBORG » Mon Dec 02, 2019 2:59 am
I picked up the Walmart 4k (Black Friday) version. And so far all the playlists you've listed I don't have on mine.
Here is the list of playlists mine has: https://pastebin.com/4VaqHGEW
stonkr
#45 Post by stonkr » Sat Dec 07, 2019 6:14 pm
I agree the UK Blu Ray playlist for me is 00527.
I normally use VLC with process monitor but VLC just stalled loading the blu ray. So I exported the makemkvcon output to a text file and played through various versions at the cut points until I narrowed down the segment map to 511,504,508,517,501,510,505,502,512,516,507,506,515,514,500,513,509 which only relates to playlist 00527.
