Help an idiot with a 1st gen WH14NS40
matrixprime
Re: Help an idiot with a 1st gen WH14NS40
Post by matrixprime » Sun Aug 11, 2019 11:46 pm
Billycar11 wrote: Sun Aug 11, 2019 11:31 pm There was no problem flashing if your on 1.02 and your drive sees the disk
pc locking up while ripping sounds like a system problem
I thought I needed to use the bin file from MK-FIRMWARE-PACK -> WH14NS40-N650 and use that to get the firmware back up to 1.03. Are you saying that's not needed? I was trying to follow this YouTube tutorial: https://www.youtube.com/watch?v=Yfpf6HoMMis
I got through all of it except for the ASUS ODD FW 3.02 Updater. I tried it and it didn't work, kept giving me an error. Are you saying that step is not needed?
Post by Billycar11 » Mon Aug 12, 2019 2:05 am
matrixprime wrote: Sun Aug 11, 2019 11:46 pm
none of it is needed if your drive has/came 1.02 this whole thing is all about downgrading not upgrading. and since you also can't flash your drive i guess you have it connected with usb?
but yeah if your dive sees 4k disks your good just need to figure out your other problem of locking up in the rip could be the usb adapters psu or something with your system.
but yeah i made the video its is about downgrading i don't say to use the asus tool i say use it if you have an asus drive i just wanted to show both that version probably only works with asus drives. and that was before the new asus tool was out that can flash any fw now.
i have been thinking about making a new better video with the updated flasher and info but i know soon as i do that mike will come out with his flasher just like right after i made the dosflash video we got de firmware lol
matrixprime
Post by matrixprime » Mon Aug 12, 2019 2:15 am
Billycar11 wrote: Mon Aug 12, 2019 2:05 am
[/quote]
Ah, that makes more sense. Well the good thing is that I can see the 4K disc in the drive. The issue is that IW didn't rip, so I decided to check using Pacific Rim: Uprising. Fingers crossed it works and if not I'll attach the logs. I am using the Vantec NST-536S3-BK 5.25 case but I see where that's on the approved list so I doubt that's the issue either. I'll give IW a good cleaning too. I don't own a 4K player so maybe it has some sort of manufacturing issue or fluid/film on it.
matrixprime
Post by matrixprime » Mon Aug 12, 2019 2:52 am
MakeMKV v1.14.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\ajaco/MakeMKV_log.txt
Using LibreDrive mode (v05 id=10F16E86E12A)
Title #00101.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.mpls was added as title #0
File 00800.mpls was added as title #1
Title #00902.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00304.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00303.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00302.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00307.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00305.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00004.mpls is equal to title 00800.mpls and was skipped
DEBUG: Code 233 at THe75J55/EOIZxNDGQxaNdIO:0
DEBUG: Code 233 at RbejqypiVHnYn6WIR/tN/G/V:0
DEBUG: Code 233 at OwW38Kal1kfhlZQQ9/AR/Z2g:0
DEBUG: Code 233 at EylznnY03cYjhEuVuzRl/GUd:0
DEBUG: Code 233 at MHqJhglVC0PI2XW79IZT/Dkv:0
DEBUG: Code 233 at fTrW0iWzIh/QbQ0onEyQa1iJ:0
DEBUG: Code 233 at 1VN5Sn8QdONU8cZDYABsaapD:0
DEBUG: Code 233 at IOF88bdHOC6TqvR7wmuxepem:0
DEBUG: Code 233 at glAdVrTBDAd0QqxA8J/pmzaR:0
DEBUG: Code 233 at NsV3uaVd6ZRkW3rh4hK4f5OY:0
Saving 1 titles into directory C:/Users/ajaco/OneDrive/Desktop/MakeMKV Output
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 1 at G>ll~IKX!cjdupY+4zj-:213131318
Hash check failed for file 00042.m2ts at offset 23314753536, file is corrupt.
The source file '/BDMV/STREAM/00042.m2ts' is corrupt or invalid at offset 23314642944, attempting to work around
DEBUG: Code 2 at G>ll~IKX!cjdupY+4zj-:213131318
DEBUG: Code 3 at G>ll~IKX!cjdupY+4zj-:213131318
The source file '/BDMV/STREAM/00042.m2ts' is corrupt or invalid at offset 31244863488, attempting to work around
Hash check failed for file 00042.m2ts at offset 31244937216, file is corrupt.
DEBUG: Code 149 at G>ll~IKX!cjdupY+4zj-:121265200
DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:121262946
DEBUG: Code 15256281 at kstXQhz>sC3xud$ta/Bp:29393286
DEBUG: Code 2 at tz\K>AUip3!R=Ie&:29395908
DEBUG: Code 0 at D8L"~H<8yPg*12}M1MpW{:213136608
Hash check failed for file 00042.m2ts at offset 31475558400, file is corrupt.
Failed to save title 0 to file C:/Users/ajaco/OneDrive/Desktop/MakeMKV Output/MARVEL'S AVENGERS- INFINITY WAR_t00.mkv
Encountered 3 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Here's the log that was generated after the last attempt to rip Infinity War
Post by Billycar11 » Mon Aug 12, 2019 4:14 am
matrixprime wrote: Mon Aug 12, 2019 2:52 am
3 things it can be
dirty disk - uhd disks are really sensitive to anything on them 1 tiny scratch can kill a disk for ripping
defective drive - i have gotten so many defective i have lost count they had alot of bad batches from 12/15/18 - 2/1/19
bad enclosure - but i dont think it is this
matrixprime
Post by matrixprime » Tue Aug 13, 2019 4:05 am
Billycar11 wrote: Mon Aug 12, 2019 4:14 am 3 things it can be
I finally got Infinity War to rip and I'm working through encoding but it did finally work. I did have trouble with Pacific Rim Uprising and have completely given up on that one.
You stated you thought the drive may be going bad. If I start seeing the debug error in logs for UHD discs and HD discs, would that be a sign the drive is on it's last leg? I'm trying Ant-Man and the Wasp now. The disc has never been touched by me and appears to be super clean so I'll give it a shot and post logs if it craps out again.
Post by Billycar11 » Tue Aug 13, 2019 7:18 am
matrixprime wrote: Tue Aug 13, 2019 4:05 am
well its hard if you don't have multiple drives im flashing 5 right now and have 1 defective
my process is if a drive gets a hash error clean the disk and retry see if the error comes back and is in the same or similar location or if completely random - same location probably means disk random places probably means drive.
try in another drive if no error 2 full rips drive is bad
obviously i build on it depending on scenario but you get the idea
bmwracer
Post by bmwracer » Thu Apr 23, 2020 5:37 pm
Hi all,
Another idiot here... I tried to change the firmware in my WH14NS40 (SVC40) and I've completely hosed the drive. The drive now thinks it's an SVC50 with firmware 1.03.
I've been trying the WIndows PE > DOSflash procedure, but when I try to read the flash, I get a "No known flash chip on this part!" message. I've done all of the necessary preliminary steps: SATA to IDE mode, moved the drive to SATA port 1, etc., but I still can't read the flash.
Have I completely bricked the drive?
Thanks in advance.
jonghotti
Post by jonghotti » Fri Apr 24, 2020 6:48 pm
SamuriHL wrote: Tue Mar 12, 2019 12:19 am Oh Jesus not Julia! LMAO Billy and I are never going to hear the end of this. :lol:
Seriously though, VERY glad you got it back up and running and that this worked to save the drive. Hopefully this will help the myriad of others that have run into this issue.
I love Julia, been using her for years! Billy occasionally throws the "too lazy to find the windows 10 PE" I agree yes, I am and carry on :-)
jonghotti
Post by jonghotti » Fri Apr 24, 2020 6:52 pm
bmwracer wrote: Thu Apr 23, 2020 5:37 pm Hi all,
Thanks in advance.
You guys are not idiots for making a mistake while flashing. It happens. Now buying an NS40 in the first place that decision definitely needs discussion :-)
But yeah let's go easy on the name calling.
If you've done al you can do with the drive I'm happy to take a shot at it. Contact info in the link in my signature. You can mail the drive and I'll do some complimentary dosflashing. People were nice enough here to teach me and continue teaching me. Happy to give some back.
bmwracer
Post by bmwracer » Fri Apr 24, 2020 10:57 pm
jonghotti wrote: Fri Apr 24, 2020 6:52 pm
Thanks in advance.
Thanks, but are there any other procedures I can try myself before I ship off the drive to you?
bmwracer
Post by bmwracer » Tue Apr 28, 2020 4:27 pm
This is what I get when trying the DOSflash procedure:
bmwracer
Post by bmwracer » Tue Apr 28, 2020 5:39 pm
Dumb luck: After poking around the site, I found the way to restore my drive back to working condition:
NS40 Recovery Image:
Flashed an NS50 firmware to an NS40 drive and can no longer read disks this IMG has all the NS40 FW you need to recover your drive just follow my dos flash video guide linked above
https://www.mediafire.com/file/8by2zqop ... D.zip/file
Now my drive is working, but now it thinks it's a WH16NS40 (1.02 firmware) rather than a WH14NS40, which it actually is. Is that a problem?
Also, it still can't read a UHD disc. The date code on my drive is 2014, which apparently doesn't fare well with the entire UHD flashing process. Should I bother trying to make the drive UHD friendly or just give up?
Suggestions would be greatly appreciated.
Post by d00zah » Tue Apr 28, 2020 5:44 pm
NS40 drives are too old. HW CAN NOT support UHD, no matter what FW you try.
bmwracer
Post by bmwracer » Tue Apr 28, 2020 5:46 pm
d00zah wrote: Tue Apr 28, 2020 5:44 pm NS40 drives are too old. HW CAN NOT support UHD, no matter what FW you try.
Time for me to buy a new one, I guess... With a recent manufacturing date code.
