LibreDrive Help
seanbrown427
LibreDrive Help
#1 Post by seanbrown427 » Sat Aug 10, 2019 7:42 pm
Hey all, I have been fairly self sufficient here but I'm confused about getting LibreDrive working. I flashed LG BH14NS40 to the Ver 1.0 from reading all the posts and am making the assumption that it is one that Mike has developed the software for since it seems to be a fairly popular drive. This is what I am getting in MakeMkv from the status screen. Is there an additional step I need to follow to get this working?
Product: BD-RE BH14NS40
Revision: 1.00
Serial number: K94ECH95744
Firmware date: 2112-06-16 18:23
Highest AACS version: 68
Drive platform: MT1939
Any help would be appreciated. Because right now it will NOT open any UHD disks and I have a few that I need to put on the HTPC.
Thank you all!
Re: LibreDrive Help
#2 Post by d00zah » Sat Aug 10, 2019 8:30 pm
This appears (FW date) to be a SVC NS40 drive, manufactured prior to late 2015. NOT UHD capable.
st4evr
Re: LibreDrive Help
#3 Post by st4evr » Sat Aug 10, 2019 8:36 pm
1. As the drive info you posted clearly states:
“Status: Possible, not yet enabled”
This feature is enabled by Mike (developer of MakeMKV) as support is added to the application on a per-drive basis. There is NO on/off switch that you/we can control.
Very clearly detailed here by Mike himself:
https://www.makemkv.com/forum/viewtopic ... 19&t=18856
2. Your drive is too old for UHD support. Discussed hundreds of times within the walls of this forum. Forum search function works:
https://www.makemkv.com/forum/search.php?keywords=2015
AND THIS:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
ALTHOUGH, I am actually surprised the flash you mention you executed against this drive did not brick the drive. UNLESS, the firmware info being reported is incorrect somehow?
When exactly did you purchase this drive?
Does it currently read ANY discs of ANY type/format?
3. Libredrive is NOT a magic pill for AACS decryption of all kinds. READ this:
https://www.makemkv.com/forum/viewtopic ... 925#p75925
