Just flashed LG WH16NS60
forstral
Re: Just flashed LG WH16NS60
Post by forstral »
Thank you SamuriHl, I do appreciate the information and will check the sticker on the drive when I remove it to put into an external enclosure.
Post by SamuriHL »
Yea, we've just seen too many people brick those drives and want to prevent you from heading down that path. Because once it's bricked by flashing the wrong firmware if it's an older drive, fixing it is WAYYYYYY more difficult than the process that gets you into that situation. So a little work up front can prevent a major headache down the road. If it's the NS50 svc code then you should be good to go to flash whatever you want.
forstral
Post by forstral »
I have removed the drive from the old system and this is what is on the tag:
Model: WH14NS40
Rom Ver: 1.03
Manuf: 12/11/2017
Svc Code: NS50
Is this one that can be flashed? Can it be crossflashed to WH16NS60 rev. 1.00
Thank you for all of your help.
forstral wrote: Sat Aug 17, 2019 7:23 pm I have removed the drive from the old system and this is what is on the tag:
Model: WH14NS40
Rom Ver: 1.03
Manuf: 12/11/2017
Svc Code: NS50
Yes it can be flashed to WH16NS60 1.00de or 1.01mk that will fix the sleep bug and make it rip faster
