Brave Disks Not Ripping Main Movie
kdheslop@gmail.com
#1 Post by kdheslop@gmail.com » Thu Aug 08, 2019 7:48 pm
I have been trying to rip Brave from Blu Ray and have tried 2-disks so far and the movie itself has failed, I noticed a shorter version of the movie today on the second disk and attempted to rip that one as a back-up, but it failed also.
I am getting the following errors that precede the aborting of the file save:
First it starts giving SCSI read errors, then says.
"800" FIle:
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 12 to file C:/Users/kdhes/Downloads/Movies/Brave/Brave_(2012).mkv
Shorter File
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 20 to file C:/Users/kdhes/Downloads/Movies/Brave/Brave -Short Version_t20.mkv
The debug and related information, if I did it right are below.
Any help greatly appreciated. Thank You
Kris
MakeMKV v1.14.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\kdhes/MakeMKV_log.txt
File 00203.mpls was added as title #0
File 00204.mpls was added as title #1
File 00205.mpls was added as title #2
File 00206.mpls was added as title #3
File 00207.mpls was added as title #4
File 00209.mpls was added as title #5
File 00210.mpls was added as title #6
File 00211.mpls was added as title #7
File 00212.mpls was added as title #8
File 00213.mpls was added as title #9
File 00214.mpls was added as title #10
Title #00215.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #11
Title #00070.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #12
File 00216.mpls was added as title #13
File 00801.mpls was added as title #14
File 00802.mpls was added as title #15
File 00200.mpls was added as title #16
File 00201.mpls was added as title #17
File 00202.mpls was added as title #18
Title 00907.mpls is equal to title 00200.mpls and was skipped
Title 00932.mpls is equal to title 00800.mpls and was skipped
Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00887.m2ts' at offset '325632'
DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:29394758
DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29395011
DEBUG: Code 0 at G>ll~IKX!cjdupY+4zj-:29394068
DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29394459
DEBUG: Code 159 at kstXQhz>sC3xud$ta/Bp:29393286
DEBUG: Code 0 at rGPRLY%mWFZr75Kr#c(L:213136056
DEBUG: Code 0 at :;Z:QQNATOWj'0b#~#:121262049
DEBUG: Code 0 at :;Z:QQNATOWj'0b#~#:121262256
Failed to decode audio/video data for title #19 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at hHx39vATTJa^z A,:29394988
DEBUG: Code 0 at yp|(szPKd:c .XJ:29401635
DEBUG: Code 0 at SYpXh>1]9aM.=fv`:121247467
Title #00887.m2ts was skipped
Title #00952.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00953.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00954.m2ts was added as title #19
Title #00955.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00956.m2ts was added as title #20
File 00957.m2ts was added as title #21
Title #00959.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00958.m2ts was added as title #22
Title #00960.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00961.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00962.m2ts was added as title #23
Title #00964.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00965.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00966.m2ts was added as title #24
Title #00968.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00969.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00970.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00971.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00972.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00973.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00974.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00975.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00976.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00977.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00978.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00979.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00980.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00981.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00982.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00983.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00984.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00985.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00986.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00987.m2ts was added as title #25
Title #00988.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00989.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00990.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00991.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 12 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
DEBUG: Code 233 at GoFpN2m+wxASk7y+bk/gyHM/:0
DEBUG: Code 233 at ve+9WNlmoe5WTbAlIFfoUGSJ:0
DEBUG: Code 233 at NBbdpbx/9yYz7yJPLilDqYhp:0
DEBUG: Code 233 at 6a750KVS7W2cV5vXVFj9rEz8:0
DEBUG: Code 233 at PNWAJk6qxUdwkXx8z3iHOHJ/:0
DEBUG: Code 233 at JjjkvAv1smaFHiDxkS+4hy3N:0
DEBUG: Code 233 at cuNzdsDqU3bJsxCh61r3RbIJ:0
DEBUG: Code 233 at atlOelp6GQf/axBKK4Ec4TCj:0
DEBUG: Code 233 at ecenv/98T0u5cz5MEGcMr4a7:0
DEBUG: Code 233 at hpTUB3r6NIVYspCmkhkTy/xu:0
Saving 17 titles into directory C:/Users/kdhes/Downloads/Movies/Brave
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'C:/Users/kdhes/Downloads/Movies/Brave/Brave SF 12_t11.mkv' (title #12)
AV sync issue in stream 1 at 0:01:29.756 with duration of 3.666ms : encountered overlapping frame, audio skew is +3.666ms
AV synchronization issues were found in file 'C:/Users/kdhes/Downloads/Movies/Brave/Brave_(2012).mkv' (title #13)
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:00:44.586 with duration of 21.791ms : encountered overlapping frame, audio skew is +21.791ms
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:01:12.864 with duration of 9.75ms : encountered overlapping frame, audio skew is +31.541ms
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:04:15.338 with duration of 22.041ms : encountered overlapping frame, audio skew is +53.583ms
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:04:15.392 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +21.583ms
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:05:13.354 with duration of 31.708ms : encountered overlapping frame, audio skew is +53.291ms
AV sync issue in stream 2,3,4,5,6,7,8,9 at 0:05:13.408 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +21.291ms
AV sync issue in stream 1 at 0:05:13.354 with duration of 0.375ms : encountered overlapping frame, audio skew is +1.125ms
AV sync issue in stream 1 at 0:05:13.355 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.291ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '2937581568'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '2937581568'
DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:29394758
DEBUG: Code 1434366 at kstXQhz>sC3xud$ta/Bp:29393286
DEBUG: Code 0 at D8L"~H<8yPg*12}M1MpW{:213136608
DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:29394022
DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:213140840
DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:29404556
DEBUG: Code 0 at f8>|gG{X=7WBEs]q\xP1:213139506
DEBUG: Code 0 at tz\K>AUip3!R=Ie&:29395908
DEBUG: Code 0 at ^tC$czn8B:EzJrThG:213132698
DEBUG: Code 0 at ^tC$czn8B:EzJrThG:213132146
DEBUG: Code 0 at ^tC$czn8B:EzJrThG:29393769
AV synchronization issues were found in file 'C:/Users/kdhes/Downloads/Movies/Brave/Brave Old World_(2012).mkv' (title #14)
AV sync issue in stream 1 at 0:03:20.366 with duration of 17.166ms : encountered overlapping frame, audio skew is +17.166ms
AV sync issue in stream 1 at 0:06:40.525 with duration of 1.708ms : encountered overlapping frame, audio skew is +18.875ms
AV sync issue in stream 1 at 0:11:01.160 with duration of 4.625ms : encountered overlapping frame, audio skew is +23.5ms
AV synchronization issues were found in file 'C:/Users/kdhes/Downloads/Movies/Brave/La luna_(2012).mkv' (title #17)
AV sync issue in stream 2,3,4 at 0:00:43.877 with duration of 26.833ms : encountered overlapping frame, audio skew is +26.833ms
AV sync issue in stream 2,3,4 at 0:05:52.226 with duration of 2.291ms : encountered overlapping frame, audio skew is +29.125ms
Forced subtitles track #6 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Forced subtitles track #13 turned out to be empty and was removed from output file
Forced subtitles track #15 turned out to be empty and was removed from output file
Forced subtitles track #17 turned out to be empty and was removed from output file
Forced subtitles track #19 turned out to be empty and was removed from output file
Forced subtitles track #21 turned out to be empty and was removed from output file
Forced subtitles track #23 turned out to be empty and was removed from output file
Forced subtitles track #25 turned out to be empty and was removed from output file
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '2913398784'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '2913398784'
DEBUG: Code 1422558 at kstXQhz>sC3xud$ta/Bp:29393286
Encountered 22 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
15 titles saved, 2 failed
