Asus BW-16D1HT 3.10 Firmware
Hopest
#1 Post by Hopest » Tue Aug 06, 2019 6:41 pm
I've watched the UHD Friendly Guide to flashing a Blu-Ray drive but before I do it I just want to check I've got this correct as my version is different to the videos.
So the version of my ASUS BW-16D1HT is 3.10-01
So do I use the bin file included in the "Downgrade Enabled Firmware V.2" which is 3.02 or do I use the bin file from the latest mk-firmware-pack-20190728 which is 3.10?
I think it's the later but just being extra cautious and can you confirm I don't need to use the ASUS ODD FW 3.02 Updater Tool that was in the 2nd half of the youtube video.
Sorry if these are stupid questions, I think you guys rock and thanks for all the efforts for making this easy and possible!
Tom
Re: Asus BW-16D1HT 3.10 Firmware
#2 Post by MartyMcNuts » Wed Aug 07, 2019 2:43 am
Tom
As your drive came with 3.10, you must flash ASUS 3.10-MK first as this firmware restores "downgradeability" to your drive. Then, if you don't want to use ASUS 3.10-MK (I don't know why you wouldn't! as it is great firmware!!) you can flash whatever firmware you like.
Hopest
#3 Post by Hopest » Wed Aug 07, 2019 5:38 am
Sir you are a legend!
Thanks for the reply,
I thought I was right in my assumptions but I thought why not ask before doing just to be on the cautious side of things.
Many thanks, can’t wait to start.
Hopest
#4 Post by Hopest » Wed Aug 07, 2019 6:29 pm
So I have followed process and it said restart PC, did this and inserted UHD and says "no disc".
Opened Downgrade Enabled program again and it says the firmware is still 3.10-01.
What have I missed?
Thanks,
Tom
#5 Post by SamuriHL » Wed Aug 07, 2019 6:31 pm
Open up MakeMKV and see what it says for info about the drive. Post a picture so we can see what it says.
Hopest
#6 Post by Hopest » Wed Aug 07, 2019 6:37 pm
It was the sdf.bin file, updated and now reading my Fury 4K movie.
Thanks :D
Hopest
#7 Post by Hopest » Wed Aug 07, 2019 6:38 pm
Thanks for the fast response, appreciate it.
#8 Post by d00zah » Wed Aug 07, 2019 7:47 pm
I thought Fury 4K was one of the two AACS 2.1 discs not (yet?) supported by MakeMKV?
#9 Post by SamuriHL » Wed Aug 07, 2019 8:21 pm
Yea I thought the same thing. LOL
Hopest
#10 Post by Hopest » Wed Aug 07, 2019 8:27 pm
Yes we’ll I've learnt that lol
I responded to soon :-(
I’ve also tried Fighter and also Mission impossible fallout and no luck yet.
Hopest
#11 Post by Hopest » Wed Aug 07, 2019 8:55 pm
Strange, tried loads of my 4K movies and no luck.
Downgraded to 3.02 and just trying Fast Furious 8 which is now read and making a MKV.
#12 Post by SamuriHL » Wed Aug 07, 2019 9:29 pm
That is strange. I'm using MK 3.10 on my BW-16D1HT and I've not had too many issues with it.
#13 Post by Coopervid » Wed Aug 07, 2019 9:40 pm
I guess you forgot to reboot after flashing 3.10 MK.
Please try again and reboot. Should work then.
Bolter
#14 Post by Bolter » Mon Aug 24, 2020 12:02 am
I have updated my Asus firmware to 3.10 MK. and everything is running great. But I did notice that is now says "Microcode access re-enabled"
what is this and what does this do?
Thank you Makemkv, keep up the great work.
#15 Post by SamuriHL » Mon Aug 24, 2020 12:51 am
That's the magic that allows LibreDrive to work.
