Rainer
Post
by Rainer » Tue Aug 06, 2019 4:03 pm
Asus BW-16D1HT 3.01
Version 1.14.4 tells me always that there is no disc inserted.
With version 1.14.3 the drive make several minutes terrible sounds before it starts
Perhaps this will help:
MakeMKV v1.14.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Rainer/MakeMKV_log.txt
The new version 1.14.4 is available for download at
http://www.makemkv.com/download/
Backing up disc into folder "D:/DVD/MakeMKV/backup/BIG_PACIFIC"
Using LibreDrive mode (v05 id=E064BA3E3F81)
Downloading latest HK to C:\Users\Rainer/.MakeMKV ...
Encountered 2 errors of type 'Read Error' - see
http://www.makemkv.com/errors/read/
Backup done
Does MakeMKV 1.14.4 have issues with this UHD?
Post
by Billycar11 » Tue Aug 06, 2019 11:10 pm
Rainer wrote: Tue Aug 06, 2019 4:03 pm
Asus BW-16D1HT 3.01
Backup done
best thing to try first is to clean the disk
then check if your other uhd disks still work if so and this disk is still not working correctly after being cleaned get a replacement
Rainer
Post
by Rainer » Wed Aug 07, 2019 6:06 am
I did all these things already.
Only with the replacement I tried 1.14.3.
I am confused why 1.14.4 says that there is no disc but 1.14.3 says there is.
spl147
Post
by spl147 » Mon Aug 12, 2019 12:29 pm
Update the drive to the 3.10MK firmware
Sent from my iPhone Xs Max using Tapatalk Pro
