too large ripp blu-ray
dtvong
#1 Post by dtvong » Fri Aug 06, 2010 7:34 am
i'm using makemkv to ripping blu-ray .after ripping take alot my hard drive space with 26.GB for one movie.
i'm using another s/w to ripping same movie only 6.6GB
can some one help?
skittle
Re: too large ripp blu-ray
#2 Post by skittle » Fri Aug 06, 2010 3:25 pm
makemkv simply dumps data off of the disk into an mkv container. As you seem to have noticed bluray's are large, so if you want a smaller file you will need to compress it with third party tools.
dtvong
#3 Post by dtvong » Sat Aug 07, 2010 4:52 am
thanks for reply
can you tell me with third party tools should i use? where can i get it.
greatly appreciate
sfbistimg
#4 Post by sfbistimg » Sun Sep 19, 2010 5:13 am
handbrake is good for shrinking or compressing the files
setarip_old
#5 Post by setarip_old » Sun Sep 19, 2010 5:35 am
can some one help?
1) What program are you using that compresses it to 6.6GB?
2) If you already have and are using a program to compress your Blu-rays, why are you seeking another such program?
