daddy
#511 Post by daddy » Fri Aug 02, 2019 4:17 pm
Hi yuseope
I tryed to make a DV+TrueHD version of "Ready player One" with your method.
All works like a charm until i m trying to add the audio to the dv.mp4 file.
C:\ESD\GPAC>mp4box.exe -add C:\ESD\mp4muxer_out.mp4:rate=0 -add C:\ESD\lpcm.mov:disable -brand mp42isom -ab dby1 -no-iod C:\ESD\mp4box_out.mp4
[iso file] Unknown box type hvcC in parent dvhe
[iso file] dvcC reserved bytes are not zero
IsoMedia import mp4muxer_out.mp4 - track ID 1 - Video (size 3840 x 2160)
Error writing data (No space left on device): 1 blocks to write but 0 blocks written
IsoMedia import lpcm.mov - track ID 1 - Audio (SR 48000 - 8 channels)
Saving to C:\ESD\mp4box_out.mp4: 0.500 secs Interleaving
Error: I/O Error
        Error: I/O Error
Any idea ?
yusesope
#512 Post by yusesope » Fri Aug 02, 2019 4:31 pm
Any idea ?
Read the output carefully!
Here's a hint :wink:
At this point, delete EL.hevc and BL.hevc and recover some space
Grencola
#513 Post by Grencola » Fri Aug 02, 2019 11:12 pm
Any idea ?
Wow you let him off easy! :lol: :lol:
daddy
#514 Post by daddy » Sat Aug 03, 2019 6:47 am
I already checked the empty space on the drive.
DV.mp4 is 70 Go
lpcm.mov is 10 Go
This should produce a file of 80 Go and i have 160 Go free on the SSD drive.
daddy
#515 Post by daddy » Sat Aug 03, 2019 7:37 am
Ok
I found the culprit
It s my temporary file drive that is too small
from: https://gpac.wp.imt.fr/mp4box/mp4box-documentation/
MP4Box usually generates a temporary file when creating a new IsoMedia file. The location of this temporary file is OS-dependent, and it may happen that the drive/partition the temporary file is created on has not enough space or no write access. In such a case, you can specify a temporary file location with the -tmp path_to_dir option.
I resolved the problem by moving the temporary files to the same folder i use to make the DV movies.
daddy
#516 Post by daddy » Sat Aug 03, 2019 9:39 am
I made 2 "dual layer + trueHD pcm" movies (Ready Player One and Fantastic beast 2) and the method works perfectly.
There is still a problem.
The audio level is very very low when you play the movie on the tv.
if you look at the iso tracks with BDinfo, you see that there is a DN -27 dB info on the Dolby atmos tracks
I think we lose the dialogue normalisation info in the trueHD --> pcm transformation.
yusesope
#517 Post by yusesope » Sat Aug 03, 2019 8:28 pm
Correct but I don't think it has much to do with your problem:
DN acts like an automatic volume control but only through attenuation (lowering)
A -27db value is telling the decoder that the average dialog is 4db higher than the -31db reference value (the reference level at which no volume adjustment is applied by the decoder) and as a result the dialnorm will reduce the levels across the board by 4 db.
As example, DTS does not use dialnorm at all.
Most Dolby tracks use a dialnorm value of -27db, so DTS tracks will usually be 4db louder.
Give us more information about your setup (Tv model, player model, pre-amp, amp, avr...)
daddy
#518 Post by daddy » Sun Aug 04, 2019 6:02 am
My setup for DV:
screen: LG 55C7
player: internal, reading files from a DS416 nas by upnp
amp: Yamaha Rx-V681
speakers: 5.1 Focal Dome Flax
yusesope
#519 Post by yusesope » Sun Aug 04, 2019 8:12 am
My setup for DV:
screen: LG 55C7
amp: Yamaha Rx-V681
The "problem" is your TV: it is a device equipped with HDMI-ARC and for this reason it can only generate a compressed 5.1-channel stream with a bitrate of 1Mbps.
The input track is noticeably different: 7.1-channel uncompressed flow with a wider biterate even up to 10 times compared to that generated by your television.
How many active channels are shown on the display of your Yamaha?
According to the instruction manual, you should also be able to view the bitrate of the audio track.
daddy
#520 Post by daddy » Sun Aug 04, 2019 2:41 pm
ok, i understood
ARC is limiting me to only non HD sounds
i will focus only to make DV with dts-hd (dts core in my case) or e-ac3/ac3 audio.
Your method works very well.
i already remade 2 dts-hd movies in 3 hours.
ragico
#521 Post by ragico » Sun Aug 04, 2019 4:22 pm
ok, i understood
I did try but it is too far complicated fo me. Hope someone will do a program for it.
Anyway congrats to you and to the author @yusesope
Grencola
#522 Post by Grencola » Sun Aug 04, 2019 4:26 pm
daddy wrote: ok, i understood
if you get yourself an apple tv 4k running the latest mrmc beta, it will play those 2 movies in DV with full 7.1 lossless audio. still need to test Amazon's fire tv stick 4k (much cheaper) as the emby beta app supposedly does the same thing. I'm just swapping TV's right now as I purchased a 75" Vizio Quantum X yesterday, so I'll test soon. if anyone owns that stick though here's a link to the emby beta: https://emby.media/community/index.php? ... a-testing/
I'm still working on a one-step program but I have little to no time right now :|
daddy
#523 Post by daddy » Sun Aug 04, 2019 5:25 pm
apple tv 4k can read dvhe.07 ?
Grencola
#524 Post by Grencola » Sun Aug 04, 2019 6:10 pm
oh no, I thought you were making single layer mp4s, my bad..
likeadoc
#525 Post by likeadoc » Mon Aug 05, 2019 1:43 pm
Hey guys,
I found an interesting paper on including TrueHD (MLP) bitstreams into ISO base media file format(mp4) - https://developer.dolby.com/globalasset ... format.pdf - I already contacted Dolby regarding a sample implementation :)
