Farscape PKW will not rip
rmoody
#1 Post by rmoody » Sun Sep 19, 2010 3:11 am
Trying to rip Farscape The Peacekeeper Wars and it errors just a second or so after it starts. Here is the error log:
MakeMKV v1.6.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Ronald Scott Moody/MakeMKV_log.txt
Title #0 was added (27 cell(s), 3:03:07)
Title #1 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/FARSCAPE_PEACEKEEPER_WARS
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213130490
DEBUG: Code 0 at ~@5:m^JR]n)bnfAgERWSx:213129639
DEBUG: Code 0 at }{8{aR.=caXQCH>Dnff:29394183
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29394160
DEBUG: Code 0 at 'KpGdm~*:Y=-6rTtu7{:29395195
Failed to save title 0 to file C:/Video/FARSCAPE_PEACEKEEPER_WARS/title00.mkv
0 titles saved, 1 failed
rmoody
Re: Farscape PKW will not rip
#2 Post by rmoody » Sun Sep 19, 2010 3:15 am
It appears to rip when the audio is de-selected. I tried ripping to MKV with DVDFab and the audio was severely out of sync, the video was way ahead of the audio.
I will try to mux the audio ripped with DVDFab to the audio from MakeMKV and see what that does and report back.
rmoody
#3 Post by rmoody » Sun Sep 19, 2010 3:46 am
Using the video from MakeMKV and the audio from DVDFab I managed to get a useable MKV after muxing the streams together. Still odd.
#4 Post by mike admin » Sun Sep 19, 2010 8:20 am
What audio track causes this? Primary audio, DD or DTS?
rmoody
#5 Post by rmoody » Sun Sep 19, 2010 2:08 pm
There was only one audio track listed, it was DD 3/2+. I will attach a screen shot for you.
setarip_old
#6 Post by setarip_old » Sun Sep 19, 2010 6:02 pm
I don't know if this has any bearing on the problem but, the Debug log indicates "Title #0 was added (27 cell(s), 3:03:07)", while the screencapture indicates the title being comprised of 25 chapters.
Additionally, online research about this first disc of a two-disc release indicates a running time of 3:02:00, not 3:03:07...
#7 Post by mike admin » Mon Sep 20, 2010 8:44 am
Looks like a new protection. Please send IFOs per instructions at http://www.makemkv.com/faq/item/8/catid/6 .
rmoody
#8 Post by rmoody » Tue Sep 28, 2010 5:00 pm
*.IFO's and error log have been sent in and attached here just in case. Thanks so much!
