I am completely locked out of using makemkv.....the current key keeps resulting in the error that the key has expired.
It should be good to the end of the month.
Can we get a fix, please?
Thanks.
Temporary key has expired - should be good to the end of the month
armyofquad
Re: Temporary key has expired - should be good to the end of the month
Forum search, "beta expired". About 150 messages will pop up with work-arounds.
And this IS the end of the July. It's not an exact date.
riconster
Same here. Please put the new key.armyofquad wrote: Wed Jul 31, 2019 12:52 am I am completely locked out of using makemkv.....the current key keeps resulting in the error that the key has expired.
T'hain Esh Kelch
Fixed that for you!Woodstock wrote: Wed Jul 31, 2019 2:15 am Forum search, "beta expired". About 150,000,000,000 messages will pop up with work-arounds.
If only there were a "cure" for the "problem" of an expiring key. Tell ya what, if you go to this page here:
http://makemkv.com/buy/
You can actually get a new, working key created that won't EVER expire. Like magic from on high!
80sGuy
New Key
New Key link here:
https://www.makemkv.com/forum/viewtopic ... 3548#p3548
