Godfather Part III
wasim274
Godfather Part III
Post by wasim274 »
MakeMKV crashes after a few seconds. The file was decrypted with DVDFab. Latest combo svq installed. Will run as a m2ts file but cannot convert to MKV.
setarip_old
Re: Godfather Part III
Post by setarip_old »
Hi!
There's no need to use any other program (e.g. DVDFab, DVDFab Passkey, or AnyDVD HD) for decrypting.
Re-rip the original Blu-ray disc (select the main movie), with ONLY MakeMKV, directly to .MKV...
**EDIT** BTW - SVQ files have nothing to do with this older Warner release, as it does not contain BD+ protection...
wasim274
Post by wasim274 »
I did do that originally and it failed. Will try to clean disk to see if helps and try again. Thanks for your advice.
wasim274
Post by wasim274 »
:D Managed to take advice and the disk has now been converted into MKV.
setarip_old
Glad to hear that ;>}
