No Drives Found on v1.14.4 Windows 10
kiam001
Post by kiam001 »
Debug log started at Sat Jul 20 11:48:01 2019 , written by MakeMKV v1.14.4 win(x64-release)
001005:0000 MakeMKV v1.14.4 win(x64-release) gestartet
001003:0020 DEBUG: Code 3221225506 at Lt[RKo\%gO`]aK^U:121271042
001003:0020 DEBUG: Code 0 at %A0\=b]TRP7iUuct:121275274
005042:0000 Das Programm konnte keine verwendbaren optischen Laufwerke finden.
Application exited at Sat Jul 20 11:49:07 2019
Gaspode
Re: No Drives Found on v1.14.4 Windows 10
Post by Gaspode »
In Windows Security Centre check the section on Ransomware Protection. If Controlled Folder Access is ON this may be blocking MakeMkv. You can allow MakeMKv through this by selecting 'Allow an app through controlled folder access'. Add to this the path for MakeMKV.exe, MakeMKVcon.exe and MakeMKVcon64.exe if necessary.
Kudos2U
Post by Kudos2U »
I have a similar issue. What can I do besides allowing an app through controlled folder access? Because it doesn't seem to help
Gaspode
Post by Gaspode »
How did you actually try this? The brute force approach is to turn off the Ransomware Protection completely and then just try MakeMKV. If this lets it work you then need to figure out which .exe files to add to the list before turning it back on. The ones I listed worked for me.
kiam001
Post by kiam001 »
After reinstall works on the Computer
